HELP! Crackling sound when playing Music
Mar 11, 2013 at 7:28 AM Thread Starter Post #1 of 4
mrinspire
I have just got a 24/192khz iDAC, and playing music with it I heard some constant static/cracking noise, do anybody know what is the problem with this? Or I have to adjust my setting in foobar? I have installed Asio.
Please help :(
*This is not a faulty unit, as I encountered same problem before with Musical Fidelity VDACII before.
Thanks
Mar 11, 2013 at 6:27 PM Post #2 of 4
Might be an issue with RFI interference, not sure though...Are you using a cheapo printer cable, or a decent audio USB cable?
Mar 11, 2013 at 8:11 PM Post #4 of 4
I have already switched to different USB cable but the noise still exist.
install asio4all
and increase the buffer
Ok, I will try and let you know.  Thanks mate :)
