Help: Connecting Fiio E10 to Active Bookshelf Speakers & Active Sub
Mar 11, 2016 at 12:42 PM Thread Starter Post #1 of 8
ztreb185
Currently I have my Powered Edifier Bookshelf speakers connected to the line out of the E10 via 3.5mm to RCA.  What would be the best way to add a powered subwoofer to this setup? The speakers don't have a sub out to connect a sub to it directly.  I was thinking a headphone splitter from the E10 line out would do the trick? So one line out 3.5mm -> RCA to speakers and the other line out 3.5mm -> RCA to subwoofer.  Both are powered units.  I don't want to buy additional equipment like a receiver so would this be the best way without compromising audio quality?
Mar 11, 2016 at 12:53 PM Post #2 of 8
There are several sub-woofers and can be connected between the source (E10) and the studio monitors (Edifer)
Here is a Monoprice Sub-woofer for $220.
http://www.monoprice.com/product?c_id=115&cp_id=11504&cs_id=1150401&p_id=605999&seq=1&format=2
What model Edifers do you have?
Mar 11, 2016 at 1:08 PM Post #3 of 8
I have the Edifier r1280t speakers.  That sub is a bit out of my budget. I was thinking something like the Polk PSW10 subwoofer which is half the price.  This sub only has speaker wire outputs and the speakers have RCA inputs.  I would need to get an odd connection adapter for speaker wire to RCA then?  Or would the headphone splitter be the best route?
Jan 7, 2017 at 4:40 AM Post #4 of 8
I know this thread is old, but I wanted to ask if you did manage to connect the 1280T's to the sub you mentioned? I'm looking to do the EXACT same thing and wanted to know if you got it to work.
Jan 7, 2017 at 6:07 AM Post #5 of 8
It doesn't work that way. If a sub has speaker cable input and output only those two are connected, and that's meant to take a high level signal - ie the output of the integrated amplifier - where it gets audio from and then spit it back out to the passive speakers.
You need three splitters. One male 3.5mm stereo to 2xfemale RCA, then use a male RCA to 2xfemale RCA on each. One L-R pair goes to the speaker, the other pair goes to the sub. Whether or not this would have any noise or whatever is not certain. It may work well enough, it may not. Adapters are cheap so go ahead.
What is certain though is that you will not have a single volume control. The E10 AFAIK only has a line output, not a preamp output, and thus is doesn't control the line output volume. Everytime you adjust the volume of the active mains, you have to reach down and adjust the sub's.
Jan 7, 2017 at 4:45 PM Post #7 of 8
I have the E10K (basically same thing as E10) and I just tried switching my cheap 2.1, 3.5 jack from the line out to the headphone out and that can control the volume.
So I'm thinking in the E10's case, anything connected to the headphone out will be able to adjust the volume solely from the E10.
Jan 7, 2017 at 8:32 PM Post #8 of 8
While not ideal, would connecting it to the headphone out work for some volume control?
In basic terms, kind of. Except a true preamp circuit doesn't go through an amplifier output stage.
If you can't detect any noise and distortion at your preferred listening levels (not that a true preamp would eliminate those if you listen at very loud levels) and would rather not spend at all, then just use this set-up.
