Perpetually
- Sep 24, 2013
Hi everybody,
I bought a pair of AKG K550 headphones one and a half years ago, and now the two channels are unbalanced (right channel volume is about 20% lower). They are still in the 2 years warranty but because my plug was rugged by my friend (so regret to lend him) 1 year ago, I can't ask the local distributor to replace a new pair for me. I brought them to a local electronic repair store today and they said they will tell me what's the problem tomorrow. I'm 70% percent sure I may need to replace the plug or with the cable together, so I'm a little worried if I need to replace my cable as well, what kind of cable should I get so that there will be no sound quality reduction or even a sound quality upgrade? or I should just order an original cable from AKG? please help me decide, really need you guys help on this!
Thanks!
Buran
Thanks!
Buran
