axim
- Dec 27, 2006
Hello!
I bought these new Sennheiser CX 95 headphones, which sound pretty good!
But I have two very annoying problems:
A short cable is connected to the headphones, wehre you can attach a remote. If you don't have a remote, you can just connect an extension cable.
Now 1.) The point where you attach the extension cable is too heavy. I need a cable clip or something like that, where can I get one, or what's the easiest way to build one? I surely don't want to use an ugly clothespin.
2) The extension cable is way too long! It's one metre, and I'd only need 30-50cm! Where can I get a short one?
Help appreciated....
axim
axim
