LithosZA
- Dec 26, 2006
Hi Guys,
I received a new Total Bithead headphone amplifier 2 days ago and recently noticed something strange.
It seems that the left side is louder than the right side. At first I though it was my hearing, but then I switched around the headphones and I still noticed that the left side of the headphones were louder on my right ear.
Then I thought it was maybe my headphones, but it also didn't seem to be the problem because both my HD-280s and my HD-595s showed the same problem.
Is there anything you guys could suggest that I might be doing wrong or do you think that the headphone amp is defective?
Additional information:
I am currently using the amp through the USB interface under Windows Vista with no batteries.
All the software volume controls are at 100% and the balance on both channels are the same.
Currently I'm using foobaar2000 -> 16bit Dithered -> WASAPI exclusive mode output. I also did try DirectSound with the same results.
Using the onboard soundcard on my laptop with my headphones it seems that the left is the same volume as the right.
