Can someone from HeadRoom please post the specs for the fuses in the HeadRoom Desktop Power Supply? I am looking to replace them with HiFi Tuning Fuses. Thanks!
250 volt slo-blo type; .63A [or 630mA]
5.2 X 20mm (5 X 20mm size will also be OK)
Remember to replace BOTH fuses in the HeadRoom DPS simultaneously for maximum ps life / performance. Also, ensure that the correct 115VAC or 230VAC number clearly displays through the small red window found on the (removable) DPS power supply receptacle.
