Headphones problems - Sennheiser.
Jun 21, 2005 at 10:00 PM Thread Starter Post #1 of 3
RyPoll
I recently bought a pair of HDR 110 Sennheiser wireless headphones. They're quite comfortable and affordable. However, there is a problem. I didn't notice this at the start but about 5 days in I noticed the voume reduction over an amount of time. After 20 minutes of use the volume begins to reduce, until after around 40 minutes the vlume is so low it's almost mute. I'm not sure if this happened when I first bought them but it happens without fail now.
Can anyone highlight the problem here, and if so post a solution?
Thankyou
RyPoll.
Jun 22, 2005 at 12:33 AM Post #2 of 3
I'm not sure, because I've never used wireless, so I'm going to guess that it is caused by the batteries in the headset draining as you use them. Again, I'm not sure what the life of the batteries should be because I've never used them.
Jun 22, 2005 at 3:46 AM Post #3 of 3
As above.
Rob.
