blackzarg56
- Aug 5, 2009
I had this dilemma as well, and went for the AD700 last minute (I actually had already placed an order for the Senns, and then cancelled it). I haven't gotten them in the mail yet, but should early next week. I was worried about them being too big, so I emailed AT support. Here's what they said:
I found out I actually have a "large" head size according to hat charts, with a circumference of 23". But anyways, hope that info helps!
*****, You and I have about the same size head and I too have trouble with headphones fitting me properly. I own the ATH-A700 which is basically the closed back version of the AD700. It is, for the most part, too large for my head. What I did to compensate was take a couple of medium size black wire ties and go around the two tubular spanners that make up the headband just above the self-adjusting 3D wing supports. This restricts how high the supports can move upwards which provides a tighter fit on my head. I am quite happy with the fit in terms of comfort, isolation from outside noise and the seal provided which is necessary for the best low frequency reproduction. The A700 is more secure than my AKG 240DF's. These ARE large headphones. The 53 mm drivers are huge by headphone standards. The earcups are quite large and the headphones probably won't win any awards for being fashionable. Forget about sleeping in them too, they are just too bulky. If you want a great sounding headphone so you can enjoy your home hi-fi system without disturbing someone in the next room however, you will be hard pressed to beat them. Keep in mind that these are an open back design and there will be sound leakage from the headphones. People near you will be able to hear what you are listening to. I do not recommend the headphones for tracking in a recording session for this reason. A microphone will pick up the sound leakage. For tracking consider the ATH-M50 Studio Headphones. SCOTT SHAW Audio Solutions Specialist P 330.686.2600 ext. 2525 F 330.686.6298 Audio-Technica U.S., Inc. 1221 Commerce Drive, Stow, Ohio 44224 |
