Griffin Powermate help
Aug 11, 2004 at 5:58 PM Thread Starter Post #1 of 8
falkon72
I just got a Griffin Powermate and although I have to admit it's cool, I'm having a little trouble with the click+left/right functions.
It seems that when I hold it down and spin the wheel to the left or right, it not only does the click+left/right hotkeys, but it also does the click/long click hotkeys depending on how long you hold it.
Is this a software flaw or is this the way its supposed to be? Or do I just have a defective Powermate?
Aug 12, 2004 at 2:01 AM Post #3 of 8
I have one of these. I got my first one sent back and replaced for free b/c my computer wouldn't recognise it as an interface device after a while. Figured it would be fixed after getting a brand new one and a fresh format which was necessary anyways. No luck as of yet, but I will admit that it was pretty nifty for the short time that i got it working!
Aug 12, 2004 at 4:16 AM Post #4 of 8
Try adjusting the "Long Click Length" option. You can adjust it from .5 to 4 seconds.
Aug 12, 2004 at 4:51 AM Post #5 of 8
no luck. It does change the time though. If I hold it down and turn left or right, but take less time than the set long click time, it does the click+turn command and the regular click command. If I take more time though, it does the click+turn command and the long click command. I hope you understand what I'm trying to say.
Aug 12, 2004 at 7:27 AM Post #6 of 8
I just tested my hold down and turn function and it doesnt send a straight click command, so maybe you are having problems with your powermate.
