HeadLover
- Jun 16, 2008
Hi
I am using Foobar2000 (and winamp)
something really strength
I have tried using it with many options, and no matter what I did - it wasn't bit perfect and there was the problem that both windows control the volume and show the "waves" and so is the ASUS driver (showing music palyed and can max all kind of volume and mixing over it)
I have found a solution - I am using foobar2000 and using the WASPI (windows by pass api) with it, and now I don't have that problem!
I can't change the volume or do to it anything (wich means bit perfect)!
and sure the sound seem to be much better! (no clipping and so on)
But
Is there any other soltuion that will enable me to play "bit perfect" using windows vista 64 bit ?
And why isn't ASIO doing it?! is something "****ed up" there ?!
Also
when turn on up sampling - sometimes my PC crush, so I disable it, I don't need it, right?
And why is that?
I am using Secret rabbit btw.
thanks for all the help guys!!
But
Also
And why is that?
