Towle
- Sep 24, 2004
I have a new soundcard and having difficulty in enabling the front sound ports on my case
There are 8 plugs that were formerly on my on-board sound labelled "Mic In" "R-OUT" "MIC POWER" "GROUND" "MIC IN" "L-OUT" "R-RET" "L-RET"
However the pins on the soundcard are not labelled and I do not know which pin needs to be attached to which plug. The manual does not cover this topic at all
the picture of the soundcard is at
http://www4.head-fi.org/forums/show...8255#post848255
You will see pins at the top labelled "front audio" with some jumpers already attached. There is no accompanying description of which each pin is for
I need some help with this to know which pin goes where !
Thank you in advance
