Foobar2000 and cd writing problem
Jan 9, 2010 at 4:54 PM Thread Starter Post #1 of 10
veracocha
Hi,
When I select ''Write audio cd'' option I get error like this ;
Audio CD burning process failed: No disc inserted (0xC0AA0202)
How can I fix it ?
I'm using Win7 64bit
Jan 9, 2010 at 10:59 PM Post #7 of 10
Because there are no current solution maybe? Seems like they know what case it, but that there are no current fix.
Jan 10, 2010 at 6:01 PM Post #9 of 10
Originally Posted by digger87 /img/forum/go_quote.gif
Have you ever tried ImgBurn? Its an excellent burning software and your Windows version is supported. And it's free!
The Official ImgBurn Website
But It's not recognize the wavpack and ape file don't convert the wav and don't create a audio cd , foobar is very usefull for this but don't work in win 7
Jan 10, 2010 at 6:59 PM Post #10 of 10
Well you're right but ImgBurn supports DirectShow:
"It can burn Audio CD's from any file type supported via DirectShow / ACM - including AAC, APE, FLAC, M4A, MP3, MP4, MPC, OGG, PCM, WAV, WMA and WV."
But you need codecs installed on your computer, K-Lite Codec Pack can be found here:
Free-Codecs.com : Download K-Lite Codec Pack 5.6.1 FULL, K-Lite Codec Pack 5.6.1 STANDARD, K-Lite Codec Pack 5.6.1 BASIC : K-Lite Codec Pack is a collection of codecs and related tools
Be shure to uninstall any prev. installs.
Then you installed the codec pack ImgBurn supports every format you installed.
You can drop Flacs, Apes, WavePack and ImgBurn can make the CD without you converting the files to waves.
You can edit or create cue's inside ImgBurn so your files get proper cd-text to!
