Fixing the sony HD3 volume problem
Jan 30, 2005 at 10:08 PM Thread Starter Post #1 of 14
Lex101
Someone on avforums has found a way to fix the low volume on the hd3. The instructions can be found here: http://www.avforums.com/forums/showthread.php?t=184051
I've tried it on my hd3 and got a significant volume increase (well worth it imho).
Disclaimer. I take no responsibility for any consequences caused by this. Using service menu is inherently dangerous, difficulties during the process could cause the device to stop functioning and irreparably damage the product. If you do damage the product in this way, your supplier will charge for repair. (As said in the avforums thread)
Jan 31, 2005 at 6:22 PM Post #5 of 14
Originally Posted by Sphinx89
Is it a significant increase?
The EU-regulated HD3 has an output of 2mW per channel while the unregulated version has 5mW per channel.
This is a 15% increase in volume. Since hearing is logarithmic, it takes ten times the power to make a signal sound twice as loud. One and a half times the power = 15% increase in volume.
Jan 31, 2005 at 6:28 PM Post #6 of 14
ah i tried it, but turned it off
im not gonna sacrifice battery life for volume, as it is fine for me as it is
the clock looks interesting though, although i didnt go into it
Jan 31, 2005 at 6:37 PM Post #7 of 14
You won't lose any noticeable amount of battery life by increasing the output by 3mW on each channel. o.O;;;
Jan 31, 2005 at 7:32 PM Post #8 of 14
Agreed.
I wouldn't be amazingly surprised to find that the battery life would be quoted as the same on both EU crippled and 'standard' units.
Feb 2, 2005 at 7:14 AM Post #9 of 14
Brilliant, works perfect!
I don't think it's gonna cost more batterypower if you don't actually use higher volumes.
This is just gonna give you more headroom in case you need it, and now you can use less efficient phones (which of course logically does cost more batterypower anyway).
Edit: BTW, I've got a NW-HD1, works exactly the same.
Backlight gets switched off and can be switched on again in the regular menu.
Feb 2, 2005 at 1:24 PM Post #10 of 14
I changed my back to the original volume as I have the hissing problem, and increasing the output seems to make the hissing louder as well. Normally I can only hear the hissing when it is dead quiet and at the start of a song, but with the volume increase its more noticable. Atm i don't really have a problem with the default volume so it's not a problem
Feb 2, 2005 at 5:48 PM Post #11 of 14
I see. Well, a fellow-Lex is always right.
I just had a long listen, it seems the player sound a little bit better, slightly more vivid.
More headroom, so louder peaks?
Feb 3, 2005 at 11:35 AM Post #13 of 14
Just applies to the EU models. It's an EU regulation that they've imposed to protect (kiddie) consumers against possible hearing loss. Means devices sold in the EU must comply with EN 50332-1 (European Standards on maximum sound output) which is:
- That mobile equipment should be limited to 100dB(A) sound pressure using the accompanying headphones sold.
- Constraints the output power of the device, hence covering any combination of equipment and headphones.
