cvt
- Aug 18, 2009
Okay, I have never purchased any real high end audio gear, but I have heard a few higher end Sennheiser and Audio Technica closed headphones before. Not knowing/remembering there models, I will try to explain the sound I am after.
Sound Isolation is a must, I spend a lot of time flying, and unfortunately, a lot of flights are on smaller twin prop planes (like the SAAB 340).
I listen primarily to Electronic (Progressive, Glitch, Dance), the other genre that clarity is important in is Classical/Soft Rock.
Of all the equipment I have, the closest to what I believe I want to hear, is what the Sennheiser PC350's produce. I have added extra venting, and added some damping inside the cans to improve the bottom end. Although nowhere near as much as other had on these forums, as more holes increased the "flapping", and caused (or sounded to me like) a loss of fidelity in the 100-300hz range.
I was basically decided on the UE TF10 (Still am) but the amount the protude out the ear is a major concern. I have long hair, and do large movements, and have concern of the being dislodges, or noise from abrasion against hair. I will be wearing the cord over ear.
The next ones getting looked at were (and my reasons for the TF10 being placed above them). If any of the points I've hears are wrong, please correct me.
TF10: Small Soundstage (this is wrong) (AU$450)
IE8: Low Sound Isolation, Single Driver, Non-Flat Response (AU$420)
SE530: Exaggerated Mids (AU$500)
CKM100: Lack of Information and Enthusiasm (AU$680)
W3: Mostly referred to as between the IE8 and TF10, seems priced quite unreasonably in that case (AU$680)
ER4B/P/S: Lack of Information and Enthusiasm, but the Isolation Claimed does sound very tempting (AU$450)
Am I on the right track?
