Good for you!I have Xiaomi hyper OS and it works pretty well
For me, crash after a few seconds of reading!
Try to search smth related to power saving features. I guess it can cut power off when noticed that smth power demanding connected.Good for you!
Good for you!
I have done all the KA17 testing in a Xiaomi phone and tablet (Note 12 Pro+ and Pad 6) both running Hyper OS, without a single issue.And I'm not the only one:
https://forum.fiio.com/note/showNoteContent.do?id=202405191556104077466&tid=4
Unfortunately It is the Android system and it's various implementations that don't guarantee stable performance across all phones.After reading (thanks to you) @Ichos , @isayfu I tried to fix the problem with my Redmi Pad SE tablet and it's still the same, crash after a few tenths of a second of reading.
You gave me the idea to use my POCO M5 with Xiaomi HyperOS, too, and everything works perfectly with the KA17.
Long hours of research await me....
Dear friend,@FiiO , And the drivers are only for Windows, so setting up custom presets on a Mac OS and loading them onto the device will not work, right?
Is it possible to download created presets from a Mac to KA17?Dear friend,
Hi, do you mean this link: https://fiiocontrol.fiio.com/
It could work in MAC as well.
Best regards
This is fantastic! When would these be available? Any idea of pricing? Will they be available on Aliexpress and Amazon?Dear friend,
Hi, yes.
Estick:
Magclip:
A cheap cable should work fine, the KA17 needs max. 600mA of current.I'm gonna order Fiio KA17 from Aliexpress next week, my phone have micro USB so I'll need a USB Type C to Micro USB cable, do I have to look for AMP and Watts in the cable or a cheap short cable will be fine? Thanks
Dear friend,Is it possible to download created presets from a Mac to KA17?
Thanks for the answer!Dear friend,
Hi, it is not supported by KA17. The preset EQ could not be adjusted.
Best regards
