K5 Pro will be available in European market soon?
[FiiO K5Pro/K5Pro ESS]Desktop DAC and Amplifier+768K/32Bit and DSD512 decoding+3 gain levels (K5 Pro ESS (Red Version) Is Available Now)
- Thread starter FiiO
It's already available in Romania.
https://fiio-shop.de/en/dac-with-amp/873/fiio-k5-pro
Not sure if they ship to Poland, but worth a try. I too am waiting for it to arrive in France (till then, I save up in bits and pieces )
Any official updates from the Fiio Guys will be much appreciated.
I'm waiting for official sale from mainstream stores with warranty, they have K5 now and most of FiiO products, I'm sure K5 Pro will be as wellhttps://fiio-shop.de/en/dac-with-amp/873/fiio-k5-pro
Dear friend,I'm waiting for official sale from mainstream stores with warranty, they have K5 now and most of FiiO products, I'm sure K5 Pro will be as well
The K5pro European version is out of stock currently. So if you would like to get one from your local seller in Poland, you may need to wait some time more. At next month or so.
Best regards
Unappreciated
- Oct 5, 2014
Are there any local sellers here in the Philippines?
Dear friend,Are there any local sellers here in the Philippines?
There are local seller in Philippines: https://fiio.com/newsinfo/47017.html
But the K5pro is out of stock now.
Best regards
I would like to chain my K3 to my K5 pro to decrease the USB slots being taken up. Is Coaxl out and TOSLINK out affected by the K3 volume control and which cable should I buy?
Dear friend,I would like to chain my K3 to my K5 pro to decrease the USB slots being taken up. Is Coaxl out and TOSLINK out affected by the K3 volume control and which cable should I buy?
No, the volume button of the K3 would not affect the optical or coaxial output. You could buy the square to square optical cable or RCA to RCA coaxial cable for help.
Best regards
PlasticBertrand
For anyone in the UK, the Fiio K5 Pro is now available for pre-order on advancedmp3players.co.uk for £149.99. No due date for stock that I could see though.
jubeishock
- Apr 15, 2017
the k5 pro is better than sound blaster
Based on?
I know the people don't like creative products, but they're doing the things well done.I dunno if you seen the g6 review from audiosciencereview , that dac is an small beast and perform pretty well.
SoundMuppet
I recently purchased and unboxed the FiiO k5 pro and I noticed that the power brick makes a sound when you shake it. It sounds like something is a bit loose inside it. Is this normal?
@SoundMuppet No that is not normal, I would contact fiio for a replacement powerbrick.That being said its most likely just the transformer not glued properly to the housing and I wouldn't worry too much about using it in the mean time while fiio gets back to you on your case.
I've tried the topping dx3 and ifi zen dac recently while auditioning headphones and I've got to say that the Fiio K5 pro produces the best open sounding and detailed sound of the 3 esp in the low end. That being said there may be serous confirmation bias as I couldn't A/B them with the r70x and am going off memory.
jubeishock
- Apr 15, 2017
