iJimmy
- Mar 4, 2012
Hey guys, I got a FiiO G01 to review, and I thought I would post it here as well!
First impressions:
The FiiO G01 comes in a clear box, neatly organized. This allows you to see exactly what you're getting, at every angle. It also has a little strap so you can hang it on your keycord / keychain (wouldn't recommend it though!).
Accessories:
The FiiO G01 comes with two rubber bands to change the look of the edge. I decided to keep mine stock (Black), as I think it looks better, and a USB charging cable. It also comes with an instruction manual / warranty. You get one year of maintenance with the G01.
Build quality: The FiiO G01 feels solid and won't break easily. The brushed aluminum / metal adds a bit of luxury to it. The gold-plated jack is a nice touch. Also, it is SO SMALL! It will fit in your pocket easily. In fact, it's around half a centimeter bigger (in length, horizontal in this picture) than my little pick box / holder...
A family shot: The Ibanez JEM 7vWH, Denon D2000 (modded, MarkL mod, D7000 cups and pads, Toxic Cables wire cable), FiiO G01 and FiiO HS1.
How the FiiO G01 sits in the guitar (top side).
How the FiiO G01 sits in the guitar (side).
USB charge port, POWER and Volume are all on the left side if the bottom side of the G01 faces upwards (the way it faces when it is in the guitar). Also note the little blue light to indicate the G01 is on.
Drive on the left, tone in the middle, volume on the right (again, if it sits in the guitar).
Drive on the left side of the unit, together with the Auxiliary in. The AUX in allows you to use other sources. I used it for backing tracks. The way you use it is you plug a 3.5mm to 3.5mm (1/8th inch) cable into it, the other end being in your source (laptop, phone, iPod). Do note that the volume of this input is controlled by the source. The volume knob on the G01 does NOT change the volume of your backing track, for example. You have to change that on your laptop, phone or iPod.
How the jack sits in the FiiO G01.
Back.
The most important thing: Sound.
I'll start by noting something about the tone: I keep it in the middle (or slightly to the left of it). Turned all the way to the right, the sound is too thin for me. Turned all the way to the left, it is muddy.
Clean (Drive: 0%): The FiiO G01 has nice cleans. No, you won't get a Fender Twin Reverb clean out of it, but that's not what the G01's target group is.
It is excellent if you want to practice at night or when you're not at home and you don't have access to a full-size amplifier. Lows, mids and highs all come out nicely. I would have loved it to be a bit warmer though. 7.5/10
Crunch (Drive: 50%): This was definitely my favorite channel on the G01. With the drive at about 50%, you get a really nice crunch on the G01, that is GREAT for jamming and practicing. I really believe this is where I'll keep my G01 most of the time. Lows are full (although there's a slight hint of processing sometimes, but you won't notice this much jamming with scales), mids are nice and crunchy, almost perfect really. Highs are clear and nice. 9/10
Distorted (Drive: 100%): This was my least favorite channel. Although still decent and playable, I felt it was too processed and actually did not have enough gain. You don't get a 50% increase in gain compared to Crunch, and you gain some mud and a processed sound for it. Lows were processed, so were the mids and highs, but they were less processed (It's still there though). Pinch harmonics were also not as strong as I would've liked. 6/10
Overall sound: 8/10
Conclusion: The FiiO G01 is a solid performer on the go, at night or in any situation where you cannot use a full size amp. It's really nice to practice and jam. It's size is like 1/50th of the Vox AC15VR behind it, but you get a lot more than that in sound quality. It feels solid, and the brushed aluminum / metal makes it feel really nice. Options for backing tracks and customization of the sound are provided by respectively the AUX IN and the Drive and Tone knobs. Overall, I give the FiiO G01 a solid 8/10. The only thing I would like is a more natural gain, and more gain.
Thanks!
First impressions:
Accessories:
Back.
Overall sound: 8/10
Thanks!
