excuse my ignorance: definitions/terms? help?
Jan 27, 2006 at 11:41 PM Thread Starter Post #1 of 8
listennow
Greetings again -
I asked a question before requesting suggestions for 100-150 HPs. I said closed, but now that I have read more hear, I'm not even sure I know what that means! What are the definitions of 'closed' and 'open' headphones.
Regards,
Claire/newbie who loves good sound
Jan 27, 2006 at 11:56 PM Post #2 of 8
The terms open and closed refer to the area around the back of the sound producing headphone driver. In an open headphone, the area behind the driver, pointing away from your head if you are wearing the headphones, has holes in it exposing it to the air outside, allowing air and consequently sound in and out. The most common example you will see of an open headphone is actually the iPod earbud, or indeed any other common earbud. If you look at the back, you will see little holes, and if music is playing, you will be able to hear it somewhat through those holes. The advantage to this kind of design is that it reduces/removes reflections/resonances created behind the driver which negatively impact the sound of the headphone. The disadvantage is that firstly sound leaks out so other people can hear some sound when you are listening, and secondly you can hear the sounds around you entering your ear through the holes into the headphone. A closed headphone does not have these holes, and is therefore sealed from the air outside the headphone. This means that sound produced by the back of the driver resonates in the small closed box that comprises the headphone, causing some degredation of sound quality, but allowing isolation both from other people hearing your headphone, and from you hearing them.
If someone else can say that more accurately and siccinctly, please help me out!
Jan 28, 2006 at 12:28 AM Post #3 of 8
Thank you very much sloth! Your def. is more in depth than I could have hoped for, and much appreciated indeed! Now my question has an other dimension:
I'll be in my own room so i can leak a bit o' sound, but I like my music LOUD. open cans [strange new word pour moi...] seem the better choice for sound from what I've read here, but just how much sound leaks is my question? If I have my vol WAY up, will it be loud outside the phones? IE, would folks in next room or in downstairs apt be able to hear it?
Jan 28, 2006 at 12:47 AM Post #4 of 8
If you are listening to music loud enough for people downstairs to hear it you will do damage to your ears pretty fast. You really shouldn't listen too extreme of a volume. Save your ears! I doubt people would be able to hear it downstairs though, next room maybe.
Jan 28, 2006 at 8:29 AM Post #5 of 8
Some open headphones leak more than others. If your environment is very quiet, it's very possible that people in the next room could hear some sound but it shouldn't be loud to them. I doubt that people in an Apt. above or below you could hear any headphone leakage; you'll need speakers to disturb the neighbors.
The AKG K1000 leaks the most
of any headphone I've heard.
The AKG K701 leaks a lot and also the ATH-AD2000, as well as the Grado RS-1 and HF-1. The HD650 and DT880 leak a bit less.
Oh yeah, take muckluck's advice seriously and don't listen at loud volumes with anything.
Jan 28, 2006 at 3:46 PM Post #6 of 8
Greetings again -
Regards,
don't be ashamed, its good that you asked rather than go on with you ignorence. I had to look up microphonics the other week even though i've been roaming this site a couple of years more than when I joined. I think there should be a sticky thread with all the terms and definition of the common to obscure to even the essoteric words thrown aroind here.
