ElectraGlide power cable comparison, Synapses2 beats Valhalla!
Nov 27, 2008 at 11:28 PM Thread Starter Post #1 of 26
Patrick82
Banned
Someone sent me a lot of ElectraGlide cables a few months ago but I didn't listen to them because I was scared I wouldn't hear a difference between them.
Today I listened to a 4 minute song and switched the cables, the difference was HUGE! I immediately fell in love with the Synapses2!
System: HD590 + EMU0404 USB + laptop
I'm using two daisy chained Genesis for both my laptop and EMU, one Genesis was not enough. For this test I will switch the power cable between wall and EMU.
Power cables tested:
2x daisy chained Virtual Dynamics Genesis 1.1 (vibration control inside)
ElectraGlide Ultra Khan II The Statement R
ElectraGlide Epiphany first model (ERS Paper inside)
ElectraGlide Synapses2
ElectraGlide Synapses2 with ERS Paper
Nordost Valhalla 16awg with 3 layers ERS Paper
Stock 18awg with ERS Paper
Switch from 2x Genesis to a Synapses2: Brighter, faster, edgier, emptier, airier, less resolution, less weight. It sounds blacker and whiter because of AC noise from the wall. It sounds mostly empty which gives a fake black background.
Epiphany: Heavier and thicker but it sounds veiled. The low-level details are missing. It sounds very warm, full and smooth. The heaviness masks everything, it sounds like a fat carpet, the music doesn't breathe.
Ultra Khan II: Muddy and dull. Resolution is lacking badly, the sounds are not distinct. Everything is covered in mud, I can't hear the music, there are sounds missing from it.
Synapses2: The highs are emphasized. It sounds emptier with a fake black background. The layering is very good, there is more space between the sounds and nothing blends together. It sounds faster and more solid.
Synapses2 ERS: Huge bass and more resolution! It sounds more like Epiphany but much faster and clearer. It doesn't sound empty anymore.
Synapses2: Emptier, harsher and edgier with lack of resolution.
Epiphany: It sounds dark with emphasized bass. Everything is grey and muddy. There is no air. The sounds blend together.
Synapses2 ERS: More dynamics, air, speed and low-level detail. The transients are crazy fast.
Valhalla ERS: Smoother, cleaner and weaker. Everything sounds flat and weak but silky smooth.
Synapses2 ERS: More open, fast and clear. It's not veiled like Valhalla is.
Stock ERS: Highs are edgy and the bass is missing. There are sounds missing from the music. It sounds more open and faster than Epiphany.
Epiphany: Duller, boomier, bigger, thicker, warmer and greyer. It doesn't sound as fast as stock. Sounds are lost in the music because they blend together.
2x Genesis: Bigger, tighter and faster bass. Tiny sounds in the music are audible. There is more low-level detail, openness, smoothness and transparency. The soundstage sounds bigger because the ambient sounds are audible. Everything is very full and open!
Synapses2 ERS: Faster and clearer highs but edgier. It sounds very neutral but a little low-level detail is missing.
I have also tried other cables in the past; PS Audio Statement, stock cables of different thicknesses, and modified Nordost Vishnu and Valhalla with ERS Paper. I have also tried using multiple conductors per signal, but one conductor was the best because it gave more speed.
All the power cables I have tried have round conductors (except for Synapses2 which has flat conductors). A thinner cable gives less bass and more speed, and a thicker cable gives more bass but the low-level details blend together so that it sounds slow and veiled. To get clear highs you need a thin cable, however, it removes bass in the process. All round cables sound rolled-off except for Nordost Valhalla which used to be my favorite cable for 3 years. However, the overly smooth and weak Valhalla is only a band-aid for bright sounding components.
Synapses2 without ERS Paper sounds empty and thin, but when it has been wrapped with ERS Paper it has the bass of Epiphany and more resolution too! It has the clearest highs I have ever heard! Even a 18awg cable is not close to this! Synapses2 is the fastest power cable I have heard. I don't hear any problems from Synapses2, it's neutral and doesn't hurt the sound like other cables do. It sounds more real life than a modified Nordost Valhalla.
Immediately after this test I ordered more Synapses2 power cables! It's not as good as the vibration controlled Virtual Dynamics Genesis, but it's a great budget cable which replaces Nordost Valhalla. When building a big system with many components, the Synapses2 is definitely the cable to use!
Nov 28, 2008 at 12:02 AM Post #2 of 26
Ultra Khan II
Epiphany
Synapses2
Nordost Valhalla suspended in cotton threads and 3 separated layers of ERS Paper. It was my reference before Synapses2.
Virtual Dynamics Genesis 1.1 Power Cable. Vibration control cures problem of round conductors.
Nov 28, 2008 at 9:21 AM Post #4 of 26
Originally Posted by pompon /img/forum/go_quote.gif
Warning ... website not exist anymore ... I will not be tempted to send my money there ...
I don't think they manufacture them anymore. Synapses2 of power cables is like the K1000 of headphones.
Nov 28, 2008 at 1:54 PM Post #7 of 26
You still have a Judge coming ?
Yes, I will put my Judge between wall and extension strip. Then I will plug multiple Synapses2 into the extension strip. This way it's like all components have a Judge power cable! The Synapses2 just passes the signal through without messing with it. I have been waiting for a neutral cable like this, I didn't know it existed already!
I will make Genesis + Synapses2 combo experiments soon! I believe it's a great bang for buck system because multiple Genesis aren't needed. Only one Genesis between wall and extension strip!
Nov 28, 2008 at 3:44 PM Post #9 of 26
Originally Posted by tubaman /img/forum/go_quote.gif
You can't possibly call that thing Nordost Valhalla anything...
I call it: 'Triple layer ERS Paper cotton thread dielectric packing tape & foam toilet paper roll separately isolated 1 conductor Nordost Valhalla power cable' The ERS Paper costs more than the Valhalla conductor inside! It's the silkiest cable I have tried. Valhalla sounds silky like dCS Elgar Plus DAC and it was a horrible match. I believe that the best cable for dCS sources is Synapses2!
I have had 2 retail Valhalla power cables and 1 demo version with green sleeve. The demo version had a very poor termination when I opened it up, but the conductors are the same. I have sliced open all my Valhallas and modified them because the retail Valhalla is boomy, veiled and slow. I need more low-level detail and speed! I got the fastest speed with a single conductor 50cm Valhalla with Oyaide 037 connectors. Synapses2 is faster than anything else I have tried, nothing is even close!
I have also tried to separate the conductors, it gave more low-level detail!
Nov 28, 2008 at 9:52 PM Post #10 of 26
...Synapses2 power cables! It's not as good as the vibration controlled Virtual Dynamics Genesis, but it's a great budget cable
Synapse 2 is "budget cable"? LOL, only in Patrick's world
BTW. What happened to your reference system?
Nov 28, 2008 at 10:27 PM Post #11 of 26
HD590 + EMU0404 USB + laptop is my reference system, it takes the lowest wattage. Based on my experiments I get smoother sound from lower wattage because there is less AC noise infecting the other components.
The difference between audio components is small if they all have the same tweaks. I have sold my dCS sources and ordered a Judge power cable instead, the Judge is a little cheaper so it's a great bang for the buck!
Nov 29, 2008 at 5:28 AM Post #12 of 26
Patrick82, I've done nothing but read about you today in fascination. Your youtube videos are very creepy and funny.
My question is this, if you're just a young guy living in a small apartment with the floor covered in components that are shielded with special paper, where'd you get the money to purchase multiple $7000 power cables?
Also, there are a lot of components in your system that could be updated, it seems unlikely that the weak link in your system is the power cable or that a special power cable for a PC of all things is going to make it sound better, yet you have these enormous power cables costing more than the rest of your equipment combined for sale.
Finally, while I listen to a lot of techno with my Sennheiser HD650s, if I were buying $7000 cables I would know that while techno is fun to listen to, there are better recordings with more information in them, classical music, jazz, vocal music that is at least properly recorded and more interesting. Techno can really only sound so good or detailed.
My money has it that --
You're actually suffering from schizophrenia, since your youtube videos are actually really scary and terrified my girlfriend. You bought a bunch of high end cables with a credit card. The credit card company wants your money back, and so you're having a sale.
Nov 29, 2008 at 2:24 PM Post #13 of 26
Genesis + Genesis + Synapses2: Edginess and whiteness is added on top of the music, it sounds fatiguing. Problem is RFI/EMI entering the cable!
Wall + Synapses2 ERS: It sounds warmer and smoother! ERS Paper is amazing!
Genesis + Genesis + Synapses2 ERS: Much warmer and bassier than above.
Genesis + Genesis: The sounds are less distinct but there appears to be more low-level detail.
Genesis + Genesis + Synapses2 ERS: It sounds more neutral, digital, clean and solid.
Genesis: It sounds emptier with a smaller soundstage. There isn't as much low-level detail.
Genesis + Genesis + Synapses2 ERS: Heavier and warmer. Fuller and bigger soundstage. There is more stuff going on in the music.
Adding a nude Synapses2 to the system hurt the sound badly because it was like an antenna for RFI/EMI infecting the cable. But when using an ERS Paper wrapped Synapses2 it didn't hurt the sound much.
Adding a Genesis + Synapses2 combo still gave a huge improvement. It is crazy how much a Genesis improves the sound. The reduction of quality after adding a Synapses2 is very subtle. I believe that when using multiple Genesis power cables, they need to be daisy chained between the wall and extension strip so that all components get as much Genesis as possible. I will try it now!
Nov 29, 2008 at 3:54 PM Post #14 of 26
I tried adding Synapses2 ERS for the laptop and it sounded the same as for EMU. I could not hear a difference when switching EMU and laptop, power cables made an equally big difference.
Ok, I tried it, now I have two daisy chained Genesis between wall and extension strip, and Synapses2 ERS plugged into the extension strip. It sounds the same as having two Genesis + Synapses2 ERS for each component. I can't hear a difference!
The Genesis is like a power conditioner! Plugging it between wall and extension strip gives the most for the money. When having two Genesis, daisy chaining them between wall and extension strip (and using Synapses2 ERS) gives a bigger improvement than using a single Genesis for each component.
Nov 30, 2008 at 8:58 AM Post #15 of 26
The fascination with electromagnetic interference is very similar to an OCD sufferer's fascination with germs.
They do whatever they can to keep germs off their skin.
Patrick82 does whatever he can to keep interference out of his audio.
But at the end of the day, you're driving yourself into madness in order to listen to techno.
