Captain
- Jul 30, 2004
Hi Can any body help out. I have just installed E-MU 1212 in to my computer which is going into a Benchmark DAC-1. It has replaced a 0404. Problem is I getting not getting a signal going into the DAC via a optical cable, on the DAC front panel I getting error and the Non PCM light comes on and goes off. I know that every thing from foobar(same setting as I was using with 0404) is going to the Patchmix as I can see a active ASIO season and the main Mix bars are responding to a signal. Could any body help out I have tried all sorts of sessions but am not getting any were. Have been going for about 3 hours and all I am doing is getting real mad.
Could any body talk me through it, so if all is set as said all should be working. Gets me thinking that their may be something wrong with the card. (I am looking to sell the 1212 so need to know if all is OK). If I put the 0404 in their are no problems.
Thanks
Cap
I have just put the guitar tuner template in and I am now getting a signal to the DAC, but can not use foobar through it Just getting the sounds from the computer for example XP start up music. So card works just have not got my setting right. Please addvice.
Thanks
Cap
