Driving a low impedance planar with 10 ohms output impedance amplifier
Apr 1, 2023 at 11:26 PM Thread Starter Post #1 of 5
nieveulv
Amp is denafrips artemis with 10ohms output impedance
Headphone is Audeze lcd xc with 20 ohms
Will this be a mismatch?
Does the 1:8 rule still in? Been reading so many different opinions on this....
Apr 1, 2023 at 11:38 PM Post #2 of 5
The 1:8 ‘rule’ is not ‘hard & fast’. As long as load impedance (LCD-X, 20) is comfortably above source impedance (Artemis, 10), the headphone drivers should be well ‘controlled’ by the headphone amplifier.
Apr 2, 2023 at 12:06 AM Post #4 of 5
Will it be "optimal" though? Im guessing for planar it should be...
The planar-magnetic headphone has an impedance curve, versus frequency (Hz), that is close to linear. This reduces ‘complexities’ faced by the headphone amplifier.
Apr 5, 2023 at 1:53 AM Post #5 of 5
Changing impedance interaction would matter in dynamic drivers (or IEMs with hybrid configuration) because the impedance curve varies with the frequency. Planars have linear impedance to frequency, so it'll likely to affect the entire frequency range the same. I use impedance adapter on my Verum 1 on tube amps.
