artears
- Feb 20, 2006
I have a question and if it sounds stupid, please bear with me
I happen to have a 2 conductor shielded cable, which does not contain any additional drain wire, it has the braided shielding though. I will start a DIY project and the instructions suggest that the drain wire should be connected and soldered at one end for some connections. I tried to twist the braided shield into another single wire which will serve the purpose of the drain wire at one end. However, the braided shield is too delicate to work and I did not have any success so far. Is there any way that I can use this wire that I have for my purposes? Any tricks? Or should I buy another cable containing 2 conductors and a drain wire as well?
Thank you for your time, I appreciate any information.
Have a nice weekend.
