Does Singxer SU-6 work with UAC1.0 (PS5/switch)?
Aug 17, 2022 at 12:26 PM Thread Starter Post #1 of 2
btbluesky
Los Angeles
Hi,
Can anyone have Singxer Su-6 as well as PS5/switch test if the USB works? I understand these consoles are under UAC1.0 standard. I've seen people mentioned that XMOS chip can work with UAC1. But I just want to confirm.
thanks
Oct 4, 2022 at 8:12 PM Post #2 of 2
I see this on the spec sheet (bold italics by me), so I am thinking no but I will try it later this week and let you know:
System compatibility:
1, Windows 7, Windows 8, Windows 10; 32/64 bit, need to install a dedicated driver
2, Native MacOS 10.6 and later, using the system comes with a driver
3, Native Linux with UAC2 compliant kernel, using the system's own driver, (tested on Ubuntu and Daphile systems, based on INTEL X86 platform)
4, Android OS 4.2 and above, the device needs to support OTG function, in general, the Android 5.0 system is supported by default, and the following 5.0 recommendations are used with a dedicated player.
