Differences between 70SB046600002 and 70SB046A00003
Oct 20, 2007 at 7:31 PM Thread Starter Post #1 of 2
trigg3rhappy
What is the difference between the 70SB046600002 and 70SB046A00003?
Both of them are the X-fi Fatal1ty Platinum, X-fi Fatal1ty FPS Pro, X-fi Fatal1ty Platinum Champion Series, and X-fi Fatal1ty FPS. Whatever you'd like to call them by. However, what's the true physical or software differences from these two exact cards? When purchasing, the only difference you can tell from the box is that the picture of the i/o front panel is located on the lower left corner for the 70SB046600002 and is located in the lower right corner for the 70SB046A00003. One model seems to be discontinued now, but it doesnt seem like I could find any differences amongst the two to distinguish them. The discontinued model is now about 50 dollars cheaper than the in current production one. 70SB046600002 is around $150-160 and 70SB046A00003 is around $200. Any help is appreciated.
Oct 20, 2007 at 8:54 PM Post #2 of 2
newegg sells 70SB046A00003 for $170
