Cube c30 shows "Failed! Repair and format" and then shutsdown
Oct 22, 2012 at 10:09 AM Thread Starter Post #1 of 2
aintemail-c30
Hi all.
My Cube c30 began to mix the songs, so I reset with a clip in the hole. Afterwards, switching the cube on, the only thing that hapend is this message on the screen "Fails! Format and repair".
Impossible to format not even with linux. Also tryed to flash the firmare (022 and 022) but no solution.
Some ideas?
Oct 23, 2012 at 8:33 PM Post #2 of 2
your dap is dead. my studio v has the same problem (which uses similar firmware possibly due to same error message) and i need to have it send back for repair.
if you managed to fix it, let me know! =)
