Creative Zen Micro - Case Solution
Mar 27, 2005 at 3:43 PM Thread Starter Post #1 of 8
ALBQ
I have seen a lot of posts relating to cases for the Creative Zen Micro so I thought I would post my solution.
Seeing that the Zen is close in size to a small cellphone, I rummaged through the cellphone cases at the cellphone boutique in my local mall. After finding an inexpensive leasther case with clear font (Tag inside is PLNK 6100) that was almost perfectly the right size, I sewed the bottom of the case shut and used a razor blade to open up the top. End result, custom leather case with belt clip.
Enjoy - ALBQ
Mar 27, 2005 at 3:50 PM Post #2 of 8
Here are the pictures
Mar 28, 2005 at 1:32 AM Post #5 of 8
Originally Posted by dragonman111
I like my altoids case. Its awesome with a remote.
hey I should get a remote it's getting annoying to open press skip or pause then hold *goes to creative.com*
Mar 29, 2005 at 1:12 PM Post #7 of 8
Bacon,
Thank you. Yep, thought I would add a case that does not utilize a mints tin. Also, wanted to be able to see the display, press the keys and glow of the edge lighting - why hide it?
Cheers -ALBQ
"And on seventh day, God rested... and wondered if his creation would fit into an Altoids tin"
