Folex
Member of the Trade: PLAudio
- Apr 11, 2009
I was wondering if anyone has had any experience with using a CnC machine to cut plastic, more precisely cutting plastic to create baffles ?
I own a prototype company. We get "plastic" cnc machined all the time. What type of plastic are you interested in? If this is for a speaker baffle, you probably don't need it cnc machined, unless there are compound curves as part of the design. A denser material, like corian, is better than most common plastics for use as a baffle. It is machinable also.
There are several 3d printer technologies. Since this is an internal part, I'd opt for strength over surface quality. SLS and FDM processes typically are more durable (very nylon like in strength) than SLA or Objet resin builds. I have no experience with the powder deposit style technologies. In any case, you'd need that same sort of 3d file to get the part machined also. The printed part will cost less, and again, since surface quality is no an issue here, I think will work just as well as CNC.
