cheezies
- Oct 10, 2003
I never usually hook up my CD-ROM's audio cable, is it important in terms of quality or just obsolete?
Originally Posted by adhoc iirc, isnt the audio cable simply an analog connector for the analog output from the cdrom's dac? if i am correct than the quality of the audio cable would not matter, since you would already be using the cdrom drive's (ostensibly) inferior dac as opposed to using the (probably superior) dac on the soundcard. |
Originally Posted by Eagle_Driver Actually, any analog connection from CD-ROM drive to soundcard will require two A/D conversions and at least one D/A conversion. Thus, sound quality will suffer not only because of the "inferior" DAC in CD-ROM drives, but also due to the extra D/A and A/D steps required of such a connection. |
Originally Posted by adhoc thanks for the clarification eagle_driver. |
Originally Posted by Eagle_Driver Actually, I mislead you somewhat. I corrected my post there. Any analog connection from a CD-ROM drive to a soundcard requires an A/D conversion after the audio signal leaves the CD-ROM drive. This means that the quality gets lost in the extra conversion step. Then, if the final signal is destined for the analog outputs, it gets a second D/A conversion, degrading the sound quality even further. |
