valinote
As per the title I can't seem to get Poweramp Equalizer working with USB Audio Player Pro on my android phone. I use UAPP to stream most of my music from Tidal, but also listen to Shoutcast radio, and some local flac files. PE works fine when using the Tidal app directly, but when I stream Tidal via UAPP I can't seem to get i too work. I know that EQ doesn't work in UAPP if you have "Bit Perfect Playback" enabled, but I have that setting turned OFF. I know that UAPP has a built-in PEQ, but all my AutoEQ and custom EQ settings for my various headphones and iems are in Poweramp Equalizer, so I prefer to use that app. I should also note that PE works fine with Hiby Music Player with Bit Perfect turned off, but I don't like that interface as much. I feel like there must be a setting in UAPP that I am missing. Let me say that I absolutely love UAPP, but I can't live without my PE. I would appreciate any suggestions or advice regarding this issue
