happybob
- Jan 17, 2007
alright guys, i finally got around to listen to my newly modded ps audio digital link iii, and as promised, here's a brief review. i compared it to my mhdt lab paradisea+ (with bendix 6385 tube). i was expecting to a very detailed 1-2 hour listening session comparing the two, but didn't have enough time and ended up listening to only 1 CD for about 30 minutes. regardless, 30 minutes turned out to be plenty sufficient as the difference was quite large and stunning.
first, my listening setup:
amp: simaudio I-3 integrated amp
speakers: totem sttaf
cd transport: yamaha cd changer
dac 1: ps audio digital link iii with full-level stage III mod by rick cullen, the builder of ps audio digital link iii (cost of dac: $995 + $695 for mod = $1690)
dac 2: mhdt lab paradisea+ with bendix 6395 tube (cost of dac: $599 + $85 for bendix = $684)
power cords: zu cable birth on both amp and dac
interconnect: zu cable oxyfuel rca interconnect
digital cable: monoprice premium optical cable
speaker cable: tara lab prism bi-wire
cd: diana krall "girl in the other room" sacd - cd layer
i listed the prices for both dacs upfront to show that in all fairness, this is not a fair comparison as one dac costs almost 3 times as much as the other one.
now on with the review, so what do you expect? by some miracle the paradisea+ would beat out the ps audio digital link III?
you know it's not going to happen. if you have seen my earlier posts comparing an unmodded ps audio digital link iii with the paradisea+, you would've already known that i had already considered the ps audio digital link iii to be at least one league up from the paradisea+. it had better bass, detail, and resolution that were unmatched by the paradisea+; however, as i also had repeated many times before, i really enjoyed the sweetness and smoothness of the sound from paradisea+. with a power cord upgrade, silver-based interconnects, and bendix 6385, i was able to improve paradisea+'s resolution, detail, and slam to make them a little closer to the unmodded ps audio digital link III's level, but now with the modded ps audio digital link III, it's not even close anymore.
right from the start, the improvement of the modded ps audio digital link iii over the unmodded version was quite dramatic. the soundstage is now about twice as wide and twice as deep, it basically fills up the entire wall in front of me, and the dynamics is also quite impressive, especially in the bass slam. i never realized my totem sttaf speakers are capable of such kind of bass! the modded digital link iii adds another octave to the bass. before, the bass already sounded very punchy and solid, well, now you can actually feel the bass (assuming your speakers/headphones are capable of going that low). the improvement in details is also quite striking, now you can actually hear the guitar player scratching the finger board in between notes. finally, the slight tinge of brightness in the pre-modded digital link iii is now completely gone. i was very surprised that my modded ps audio digital link iii, still a solid-state dac, had a sweeter and smoother mid-range and treble than the paradisea+ tube dac.
i listend to the modded ps audio digital link iii for about 20-30 minutes using a couple familiar tracks from the diana krall cd, then i switched to the paradisea+ and listened to those tracks again. it took me less than 5 seconds to hear the difference. the comparison is similar to the one i made above between the modded and unmodded digital link iii, except the paradisea+ had more midrange sweetness but slightly less resolution and significantly less bass than the unmodded digital link iii.
anyway, hope this helps. i haven't had the chance to compare the usb inputs or the better coaxial input. i would imagine with the modded ps audio digital link iii, the usb to sound slightly worse or about the same as the optical input, and the coaxial input (upgraded during the mod to wbt nextgen rca jack) to sound even better than the optical input.
if you can afford it, by all means give the modded ps audio digital link iii a hard look. you are unlikely to find anything better under $10k or even over $10k. it really made the cd-layer sound better than the sacd played through my oppo 981. it also beats paradisea+ in every single area. but if your budget is under $1000, even though i think the unmodded ps audio digital link iii still is better than the paradisea+, some people may prefer the paradisea+ because of the sweetness and smoothness it brings.
