Bjrmd
- Dec 26, 2011
[MOD][AUDIO] biQuads - Utilizing Qualcomm's Audio Codec for Headphone Compensation
This mod is not just another collection of black-box sound "enhancement" libraries. There are plenty of those in this forum. The uniqueness of this mod is its ability to offer highly flexible and truly personalized headphone compensation filters. The potential of this proposition becomes clear when you realize that audio "quality" is experienced on a very subjective/individual level. The final compensation filters as obtained by the attached app simply require a modification of a single text file (mixer_paths.xml) that control the IIR filter as offered by the audio codec (Qualcomm only!). The audio mod itself is independent of kernel, ROM, and audio playback software used.
Introduction
The aim of this mod is to offer the user of a rooted Qualcomm-based Android device running Lollipop or later the ability to take full advantage of the IIR filter implementation offered by Qualcomm audio codecs (WCD93xx). The IIR filters are implemented in hardware as a cascade of five biquads that can be designed independently. Before diving into your own filter designs, you may want to visit this website to play with an interactive visualization of biquad filters. The mod and associated app (flashable zip below) aims to provide a similar design experience right on your device.
The advantages of using Qualcomm's hardware filter as opposed to other equalization filters offered by software implementations, such as Viper and friends are:
Installation instructions
If you are interested please see the details at XDA
This is not my mod or work in any way but @chdloc is not able to post here yet(not a member long enough) and asked me to do so. I have been using this mod on my rooted note 4 for the past 6 mos with excellent results.
Introduction
- the filters are implemented in hardware and independent of the ROM, kernel, and media playback software used
- the additional impact on battery usage is virtually non-existent
- no black box: the user has full control over the design; the filters can be designed to avoid any distortions to the audio signal
- make sure you have busybox installed
- flash the attached zip using a custom recovery (tested with TWRP)
- prepare your mixer (/system/etc/mixer_paths.xml) to accept the hardware filter. This is the most complex part of this mod. Unfortunately, this needs to be done manually as each device is (potentially) different. This post hosts the relevant sections of various devices, which will hopefully be updated regularly with new devices.
