kramer5150
- Sep 20, 2004
Is this harmful to the chip?... baking it at 375?
Originally Posted by aerius Rube Goldberg method: Use solderpaste. Trace the pad pattern onto a thin sheet of aluminum, use a fine Dremel bit to cut out the holes. Place aluminum sheet on top of PCB such that the holes line up with the pads. Put some solderpaste on top of the aluminum. Use a credit card or other such plastic card to squeegee the paste through the holes and onto the pads. Carefully lift the aluminum sheet off the PCB. Place the chip on top of the solderpasted pads. Place the PCB into a cold toaster oven. Set the temperature to 375°F and bake for about 5-7 minutes. Turn toaster oven off, open door, allow to cool to room temperature before removing. Presto! One soldered SOIC! ![]() |
