Best Setup Options Using HD800/S for Virtual Surround Gaming and Movies
Jan 16, 2017 at 1:04 AM Thread Starter Post #1 of 18
Italiano86
Hello everyone. I've been looking into getting a good headphone setup recently and have a few questions after reading a ton of articles on the subject. Long post but I definitely have some important questions.
I am looking at the Sennheiser HD800 or 800S at the moment. Kind of leaning towards the 800S since they come with a nice balanced cable and have the fix for better acoustics built in, or so I have read so far. My budget can fit either of these in plus another grand or two for an amp/dac setup if need be.
I plan on using these for gaming and music extensively from my PC, and since I am in a multi floor condo I will also use them to watch MKV movies from my pc to my tv and receiver.
First and foremost I want to be able to achieve virtual surround with my gaming and movies. Music will be fine in stereo and I don't see a reason to upmix a good stereo signal.
Will running an spdif/coax cable from a good sound card to an external DAC and then to an amp be overkill or cause any issues? I realize a sound card is still a DAC/amp combo, so will my sound card send a virtual surround signal just fine to another DAC and amp?
I am planning on upgrading to a high end marantz or denon receiver very soon as well, and am wondering how these fare with the headphone output and what sort of headphone surround they can reproduce. Can these drive a high OHM headphone like the 800s? Movies will be going to the receiver from the PC via hdmi, and only music occasionally when I want to listen to music on my 7.1 setup. Otherwise Gaming and music using headphones will come from my PC only.
I am looking at all the Schiit amps and dacs, and am pulling my hair out trying to figure out what a good setup would be for my situation. I am thinking if I go with a good combo it may be useless or unnecessary to use from my receiver, and may only be beneficial to use from my pc's sound card with virtual surround. Not to mention having a high end setup running from my pc for headphones may be a pain to unplug and move half way across to my living room receiver to watch a movie via headphones, or is there a good solution/compromise to this?
So what are some good setup options? I am thinking of getting a decent asus or creative card with an optical output to an external DAC like the Schiit Modi II Uber, and then using a MJOLNIR 2 which has a XLR output for the 800S. Or I could just use the magni 2 if the MJOLNIR is completely overkill for my situation. or go with a Lyr, Valhalla, or Asgard.
Would using a Modi 2 with a high end amp be a bad combo? I am thinking a DAC with multiple inputs, such as optical, spdif and such is a good route to take. I like the idea of the JOTUNHEIM but it lacks optical in and XLR output for the headphones, and using usb would defeat the sound card virtual surround, correct? How good is razer surround in this situation vs a sound card output? I feel like I need a DAC that can handle spdif/optical, but will this cost more or limit my options from a plain Modi non uber since it doesnt have optical?
Should I forgo the modi 2 or similar DAC and just use another type of connection from the sound card to a good amp? Again, I need virtual surround for games and movies.
Back to the receiver for movies. Should I just bypass my receiver and stick to my pc setup for the headphones and watch from my tv screen across the room? I suppose I could get a very long cord and do this, thus having my computer take care of the audio processing instead of the receiver. But If I get a good high end receiver would it be beneficial to just plug my cans into the front and let it handle the surround? I am thinking the receiver would be no match for some 800s's compared to using a good schiit amp/dac.
Again, my computer is on one side of the room, and my home theater setup is about 15 feet away with the couch and such. So I am trying to figure out logistics/what's practical equipment wise. I don't want to spend a ton on a good dac/amp setup if all I need is something basic, or if it would be pointless with a good receiver.
I will be on my pc probably 90% of the time for gaming and music, and the rest will be on my HT setup either using my 7.1 or headphones for movies from my pc, or console gaming.
I know this is a long post with a ton of questions, but I would greatly appreciate your feedback for my situation. I have read a ton so far, and am still trying to figure out a good a practical solution to my situation.
Thank you!
Jan 16, 2017 at 1:41 AM Post #2 of 18
High impedance doesn't mean that the headphone requires a lot power. Sensitivity is what determines it. The HD800/S is quite sensitive so your soundcard will be able to drive it, but being able to drive it does not necessarily mean the pairing is optimal. The HD800S is a bit picky with amp, the HD800 more so which, in my opinion is fine for gaming and movies, but may be an issue for music. If you're concerned, about the pairing, I think the Modi 2 and Vali 2 is a better pairing than the Modi 2 and Magni. You could also consider the Mimby but I haven't heard it so I can't say my impression, but from what I've heard it's much smoother than the Modi 2 which is a bit digital sounding.
Jan 16, 2017 at 2:35 AM Post #3 of 18
Lemme just preface this whole post: I do not own, and have not heard, the HD 800 or HD800S, but I can speak to basically everyone of your questions because none of them explicitly deal with that pair of headphones.
What kind of audio do your movies have? MKV is a broad container format - inside there will be a stereo or multi-ch or [something] soundtrack for the content. What is it? Or what is it predominately?
First and front: have you ever actually tried virtual surround with headphones?
Here's some demos:
https://www.youtube.com/watch?v=04yEtZJVpyY
https://www.youtube.com/watch?v=0NirHR5l9AU
You need headphones to use them, obviously.
Why am I starting here? Because very broadly speaking stereo headphones, plus stereo ears, plus stereo signal, will still give you a very convincing 3D presentation - you don't need 999 speakers to have "surround" (and I'd even question 7.1 in a condo - unless your room is truly big enough, 4.1 or 5.1 is probably the right choice).
I would not suggest running music through a surround simulacra, and whether or not you like the effect with videogames or multi-channel content (e.g. movies) is going to be personal preference - there is no absolute, hard and fast rule here. Also remember that a lot of newer videogames have their own "headphone" output modes.
No it won't cause issues, and the answer to whether or not it will work is that it really depends on the soundcard. Some will pass their DSP output via digital, some won't. As far as this route vs any other route, its really down to preference. Personally I would be more apt to go soundcard + amplifier vs soundcard + DAC, because most higher end soundcards (Asus, Creative, HT Omega, good integrated audio (yes its really getting that good, and standalone soundcards these days are a pale imitation of what they once were)) will have pretty good line out sections, and before you go down the "well but it costs less so it must be worse" road - you're not paying for an enclosure, a power supply, UL certificate, extra connectors, etc by having an add-in card.
Marantz and Denon are basically the same thing these days, or at least were for a while (most AV receivers these days are basically the same thing with whatever marque plastered on the front - there's really not a lot of variation), and as far as I know neither offers a proprietary HRTF feature, but Dolby Headphone shouldn't be impossible to find. Yamaha has Silent Cinema which a lot of people report liking, and personally I think CinemaDSP is better than any of the no-name knock-offs (e.g. anyone who isn't Yamaha, excepting Harman and LOGIC7, which you can't really get anymore because Harman (evidently) isn't interested in being an audio company these days).
Anyways, yes the receiver should probably do fine, and may be suitable as the only box you need, however you'll be taking PCM multi-ch from the videocard, so you're beholden to whatever the software solution can do there - there's none of the DSP packages that soundcard drivers offer. There'd be nothing wrong with your AVR being the center "hub" for all sides here.
There are a lot more companies out there than Schiit.
I'm not understanding the other question - are you intending to have the PC in location A and the receiver in location B, and then somehow interconnect them for "movies" but that won't work for "headphones" (for some reason)? Can you elaborate or clarify that?
The soundcard is a waste of money in this configuration. If you're just running digital out, there's no reason not to use onboard (and honestly, there's not a great case for modern soundcards beyond that anyways), or USB to whatever device.
"Balanced" drive is its own can of worms, and you'll find wildly varied opinions on its usefulness. Ultimately "your money, your choice" rules the day, but from where I'm sitting, there's not a great reason to spend a whole bundle extra for it.
Probably not. Differences between DACs are generally very subtle (especially if you're not doing a direct comparison), but some "high end" components tend to have pretty meagre specifications and live in their own reality distortion field (note that I'm not pointing any fingers here).
Sure why not?
Most DACs should accommodate this.
I like it better than any surround simulacra I've used with a soundcard, excepting Razer ESP (yes, believe it or not, Razer used to make soundcards), which I consider it to be on-par with. I prefer it significantly to SBX and say good riddance to the hassle of Creative drivers and X-Fi.
If you need S/PDIF then you need a DAC that supports it (and you could make a very sound argument that S/PDIF input is pretty much a hallmark of a "real DAC" - USB-only devices are better regarded as soundcards). However if you're coming from a PC, in the era of pure software audio, I don't see why Razer Surround Pro + whatever interface you like (and this does not need to cost "a grand or two") wouldn't be really excellent.
An actual amplifier will only accept analog inputs, so you need something to get, figuratively speaking, from here to there.
There is no "audio processing" going on here - its all software. With the receiver via HDMI you're sending stereo or multi-ch PCM from the videocard out to the receiver, and then its doing whatever its doing, and then you get an output. Conversely you could connect some amplifier/whatever device to the computer for driving the headphones, and send the video along to the receiver. There's lots of options here.
The marketing associated with headphone amplifiers is quite frankly overblown and out of control - its a lot better now than it was a few years ago, but they really are selling a niche product on the premise that you "need" this (and need to spend a whole lot of cash for it) because nothing else can do what it does, when in reality LOTS of other devices can do what it does. In my experience, good receivers that have good sound quality and good everything else are just that: good gear. And there's no reason they can't drive headphones well either. That doesn't mean a good headphone amplifier is "bad" though - its also good gear. There's a lot of ways to skin this cat.
A big extension cable (Grado makes a very nice one) could work, but now you've got a big cable running across the floor, and you're in one spot, and the volume control is in another. A remote could very probably solve that, but if you want to switch back to speakers, you're walking across the room to unplug.
Or you could have your receiver by your computer, and run long speaker wires out to the further-away speakers, and you're local to the receiver when you're local to your PC, and use the remote for when you're sitting by the TV. Or have the receiver at one position and something to plug the headphones into at another (e.g. an amp, a soundcard that has an amp, whatever).
Some logistical things to consider:
- I have yet to see an AVR that does not auto-switch between its speaker outputs and headphones when the headphones are plugged in (e.g. you plug them in, speakers are muted, and headphone out is active).
- Running two (or more) audio outputs from the PC will require switching between them in software whenever you want to change.
- AVRs generally (as in, assume 100%) will not act as line-out DACs, so if you send S/PDIF or HDMI in, you aren't getting an analog signal out via loop outs or similar.
Were it me, I'd consider what kind of AVR or SSP I could afford, and how lazy I felt - if I just wanted pure plug-and-play I'd pick up a nice AVR or SSP and set it up at the desk, and run longer lines for the speakers, set the computer to audio via HDMI, and grab Razer Surround Pro if I really wanted the surround simulacra. Then plugging/unplugging the headphones switches the speakers in/out.
If I felt less lazy, or wanted to go really cheap on the surround sound package, I'd evaluate if the motherboard/computer I'm using has decent integrated audio, and if yes, go for an amp or amp+dac, and if no, go for a soundcard (be it an internal or external model). If I still felt fairly lazy but was going this route, I'd probably consider Sennheiser's matched amplifier for the HD 800, the HDVD800 (note that I have not personally heard this setup, but its an all-in-one package and your budget sounds like it can float it, and IME matched pairs usually have the best synergy).
If I felt even less lazy (read: I want to have more stuff to mess with), I'd get a stand-alone soundcard, DAC, and amplifier, all of the connecting wires, etc and deal with hooking all of that up and all of the assorted configuration and on and on with that, plus whatever multi-channel setup. This would be my least preferred option, regardless of budget, because its more stuff to deal with on a daily basis.
Out of interest, what console(s) are being integrated here? If you're going with a PC-based solution that may limit connectivity options for the console<->headphone interface, but depending on what you're hooking up, it may not be worth worrying about (e.g. if you're talking about a SNES, I'd say don't bother).
I'd also critically evaluate if the room (and budget) is big enough to do 7.1 right, and if not, seriously consider 4.1 or 5.1. Better to have fewer quality speakers that are correctly set-up than more mediocre speakers crammed into every nook and cranny.
Jan 16, 2017 at 1:13 PM Post #4 of 18
I will definitely consider those options. Appreciate the feedback! What sort of issue for music are we talking about? Will I notice all the flaws of most music? What is the advantage of going multibit? Still trying to understand what that's all about.
As far as audio goes, I have mainly dts-hdma and True HD in my mkv's. I also have regular dts and ac3 tracks as well, with the majority being in 5.1. Most of the lossless tracks are in 7.1 and 5.1 to give you an idea.
I have experienced the virtual surround, and have looked at those demos before. Stereo is fine and all, but using virtual surround I feel adds a ton to most of the games I play, and I can better pinpoint where someone is on the screen and feel more immersed this way. I feel like I will get alot more and enjoy more with virtual surround than with just a regular stereo signal.
So running a digital signal from the sound card will not cause any distortion, correct? Wouldn't a standard line out jack from the sound card, going to, say, a regular modi 2 with regular rca jacks be analogue, and pick up any interference from the sound card? I feel like this would negate the point of getting a good DAC. Also, if I went the sound card to amp route, wouldn't I run into the same issue, ie sound card to amp would be analogue and prone to interference? Or are there good amps with an optical/coax in?
I will most likely get a new asus card since i like dolby headphone, as long as it runs well on windows 10 x64. I can go with a creative card and I have the x-fi fatality already, but the drivers are horrible and I really don't want to mess with creative anymore.
I think what i was getting at is whether or not I get a good dac/amp combo and keep it at my computer desk, and sometimes move it to where my receiver is when I watch movies. Unless there is a better solution to this. Here's some pictures of my setup:
Pics
Unfortunately I can't post them in here directly. As you can see, moving my receiver to my desk would not be feasible. To make my life easier, I am thinking I will just use my headphones on my pc, then when I want to watch a movie with virtual surround, whether coming from the pc or receiver directly, I'll go to the couch and use the tv. Hopefully this makes more sense.
I have used onboard sound, and while it is adequate, the software is another issue entirely. Getting surround to work properly with drivers in windows 10 is a major pain, especially since my motherboard from asus is almost 6 years old and does not have the driver support for the hardware anymore. I am thinking dolby headphone with a good asus card would be alot better than razer surround, but please correct me if I'm wrong. I'm not afraid to spend 40 bucks on an asus pci card to achieve this.
I get what you are saying. My receiver has to process the mkv audio basically. I don't see how my pc could do this from a lossless audio track without turning it into a core track and basically negating the point of lossless. Or is there a way for my pc to process it into virtual surround while retaining the fidelity? I am fine getting a 15-20 foot cord for my headphones, or an extension and running them from the receiver if this is a better way to watch my movies sound wise. Again, if you think the receiver is fine for the cans.
I wouldn't mind this option honestly. I already switch my audio outputs on my computer multiple times a day. Basically having to take my cans from my pc to my receiver would be fine as long as the receiver would be a good fit for the headpones. I guess it really boils down to if I'm wasting the potential of owning a good dac/amp setup and only using it while I'm on the pc. I have an xbox one at the moment which is sending a pcm stream to my receiver. Again, this is why it's kind of important that the receiver can do some decent virtual surround for me.
As far as my room setup goes, I have an HK 2600 which is going to be replaced soon since it's always given me issues like random loud pops, and I get a ton of static going to my speakers.
I have a klipsch rc-64 center, RF-82's, RB-61's for my rear left and right, and rs-42's for my side surrounds. My sub is a 15" Premier Acoustic PA-150. I realize this is a bad setup for my new condo, but I've had this setup for some time, so I may as well use it. My room is huge as well, about 14x25 not including the open kitchen in the back. I love my setup, but don't want to piss my neighbors off, hence why I am looking at some killer headphones and setup options, so I can enjoy the full sound (even if it's virtual) that my blu ray rips can play.
Thanks again for all the feedback, I really appreciate you taking the time to write all that!
Jan 16, 2017 at 2:20 PM Post #5 of 18
My two cents.
If your going to be investing in a nice modern A/V receiver, skip buying a separate DAC/amp and just plug the headphones into the receiver.
The Sennheiser HD800 headphones are 300-Ohms, which is a good impedance for use with receivers.
Get a lower costing sound card for the PC and run optical from the sound card to the receiver.
The sound card can process headphone surround sound and send it thru optical, to the receiver.
Most A/V receiver do not come with what I would call true headphone surround sound (my opinion).
Just not improtant enough feature that people really pay attention to when buying a receiver.
Yamaha receivers do come with Yamaha's own headphone surround sound function, called Silent Cinema.
Sometime or another a few Marantz's units did come with Dolby Headphone.
But as long as your PC's sound card is does the headphone surround sound processing for all the PC stuff, your receiver does not need to have that feature.
At a later date you can always buy a separate DAC/amp, to use with the PC
Jan 16, 2017 at 2:57 PM Post #6 of 18
So you are suggesting to use my receiver for EVERYTHING essentially, for movies, games, and music from my pc?
Would running an hdmi cable to the receiver from my video card already provide the proper audio, and basically make an optical cable redundant or pointless? But I suppose my option is also to either get the sound card with it's own virtual surround processing and use optical to receiver, or run the video card hdmi with razer surround? Not sure if the second option would even work or be as good. Thoughts?
I'm pretty set on getting either the marantz of Denon for my setup, so I'll have to see what they provide sound wise for headphone surround. And forgoing the amp/dac isn't a bad idea either since this new receiver is going to run me around 2k+.
Would another cheap option be to get a basic dac/amp from creative or something that has dolby headphone and use that for my pc audio for the headphones?
So heres the thing with the virtual surround coming from the pc. I have the software process this, whether via razer surround or I get an asus card for dolby headphone. This then goes to the receiver and the computer will be sending the virtual surround to the receiver, correct?
Next, with the headphones plugged into the receiver, will the receiver just send the pc signal straight to the headphones, and not process the signal further? (Basically getting the virtual surround straight from the pc)  I would think a pass through to headphones wouldn't work with the receiver.
I could get two long cords/extension cords for the headphones I suppose, and run one from the receiver to my desk for gaming and my pc (only issue is volume control not within reach, unless I get an IR adapter for the remote, or use an app on my phone to control it), and then use the other from the receiver to the couch, so I don't have to keep moving cords around. Is this practical, and will anything greater than say 20-25 feet cause an impedence issue?
So I guess ultimately, do I want my audio signal to be bypassed on the receiver when using headphones? Assuming my pc is processing it.
Lastly, if I'm playing a true-hd or hdma movie through mpc or zoom player, and LAV audio is converting the signal to PCM and that is what I am hearing, is it still the same quality with virtual surround?
I really appreciate your feedback, and you will probably save me a ton of money, haha.
Jan 16, 2017 at 7:55 PM Post #7 of 18
Would running an HDMI cable to the receiver from my video card already provide the proper audio, and basically make an optical cable redundant or pointless? But I suppose my option is also to either get the sound card with it's own virtual surround processing and use optical to receiver, or run the video card HDMI with Razer surround? Not sure if the second option would even work or be as good. Thoughts?
I'm pretty set on getting either the Marantz of Denon for my setup, so I'll have to see what they provide sound wise for headphone surround. And forgoing the amp/dac isn't a bad idea either since this new receiver is going to run me around 2k+.
Would another cheap option be to get a basic dac/amp from creative or something that has Dolby Headphone and use that for my pc audio for the headphones?
So here's the thing with the virtual surround coming from the pc. I have the software process this, whether via razer surround or I get an Asus card for Dolby Headphone. This then goes to the receiver and the computer will be sending the virtual surround to the receiver, correct?
I could get two long cords/extension cords for the headphones I suppose, and run one from the receiver to my desk for gaming and my pc (only issue is volume control not within reach, unless I get an IR adapter for the remote, or use an app on my phone to control it), and then use the other from the receiver to the couch, so I don't have to keep moving cords around. Is this practical, and will anything greater than say 20-25 feet cause an impedance issue?
HDMI can carry up to 8-channel of PCM (un-compressed) 24-bit/192K of digital audio.
S/PDIF (optical/coaxial) can carry 2-channels of PCM audio, 24-bit/96K or 24-bit/192K
Or up to 6-channels of encoded (compressed) 24-bit/48K of digital audio.
I kind of doubt any games take noticeable advantage of anything above 48K.
A modern Blu-ray movie disk (with True-HD or DTS-Master audio) might sound better using HDMI, over compressed audio.
So HDMI is preferred as it pass full audio with no need for compression.
But if you use a sound card to process headphone surround sound, headphone surround sound is only 2-channel audio.
So you can use S/PDIF (PCM) and get full audio quality with the headphones.
You can just run both HDMI and optical to the receiver and use whichever sounds best to your ears.
Can't offer any valid opinion on Razer.
I currently use my PC for playing Blu-ray movies to my 58" 4K TV.
But ordered an new Blu-ray player, with 4K up-scaling, as it's nice to be able to sit on the couch and have a remote in hand.
Jan 16, 2017 at 9:05 PM Post #8 of 18
Well the HD800/S in general will reveal most flaws regardless of DAC/Amp used. As for the DAC and Amps, the HD800/S (the HD800S less so) will be quite picky with them, as they reveal the "sound signature" of the amp. It's not so much an issue of quality, but more of preference as some amp may be too bright (the Modi 2 and Magni 2), etc for some people's taste but YMMV. In my experience, I found the Modi 2 and Magni 2 too be to glaring but other than that, it has no issues powering it. Multibit is basically just using a different method to convert the digital signal to analogue. Most DAC use a delta-sigma architecture and a multibit, well uses a multibit architecture. Concerning the sonic advantages of multibit, I have to disclose first that I have not owned nor tried any multibit DAC, but from other members response, they have said that the multibit sounds a lot smoother and isn't as peaky as the Magni 2.
Jan 16, 2017 at 10:34 PM Post #9 of 18
Appreciate all the feedback guys. I think I will end up going with a new Denon X6300 which will work well with my current setup, and I read that it can easily power an 800s. I also read that it has it's own headphone surround called virtual surround, which will still put a lossless signal into the headphones in full surround which would be perfect for me. I think I will run the cans from the receiver for movies, and give it a shot for games as well. I will try the optical, and hdmi method out.
I am wondering how hdmi will work if the game doesn't do a good job of outputting surround. Obviously Using a soundcard with virtual surround would hopefully alleviate this issue.
So as you say, the soundcard would technically output the virtual surround as a 2.0 headphone channel, so optical or coax wouldn't cause any quality loss? My alternative would be razer surround I suppose so I'll have to try that out as well.
I just thought of another problem unfortunately of using the receiver for all my audio. My roomate will occasionally want to use the xbox on the tv which is fine, but will tie up the receiver and I will need something to still use the cans on my pc while this happens.
I am thinking that maybe it would be a good idea to get dac/amp combo for this situation and I think the Jotunheim would be a perfect solution. Thoughts? I can float 4-500 for this option, and it may even work better than using the receiver for my pc audio while I game or listen to music in the end.
If I get this amp with the built in dac, I will obviously have to use razer surround, since usb bypasses the sound card, correct?
I can go from the sound card to the Jotunheim via old school rca cables as well, correct? Now if I do this, won't the rca cable be prone to interference? Also, is it very likely the sound card will introduce noise as well going to the amp? I figure this is the one advantage to using an external dac.
I will probably get the amp with the dac built in just to have the option and I can use it on my laptop as well.
I suppose the other option would be to get the modi 2 uber as an alternative dac for the Jotunheim, and it would allow me to use coax or optical to eliminate any interference from the sound card, or would this be overkill or pointless?
Thanks again for all the feed back guys! I am getting pretty close to finding a good solution for my setup.
Jan 17, 2017 at 12:23 AM Post #10 of 18
So basically you're getting AC-3 or DTS from those, which will be decoded by whatever media player. You can very likely bitstream the MA or MLP audio via HDMI however. The Dolby and DTS decoders include downmix coefficient matrices to put that content into stereo, or you can use some HRTF simulacra (like Dolby Headphone) to do a bit more processing there. It will really come down to personal preference as to what you like best.
I'd look at Yamaha and their SilentCinema function then.
Yeah that sounds like an issue with the receiver, and I can't honestly say I'm surprised to hear its an HK either...
Smoke'em if you got'em, right?
Big chunks of your reply weren't grabbed correctly by the quote (this is not an uncommon issue on Head-Fi IME), so that's why the following looks out of order (because it is!):
If you like the effect with your games, by all means go for it - I enjoy Razer Surround with most games, and like I said, that's the option I'd take instead of being chained some proprietary device and its driver combo just to have that functionality (and the "calibration" feature is actually useful IME). My whole point was that there's a massive amount of hype in the "gaming world" about "you need virtual surround 7.1 surround for 7.1 in headphones 7.1 7.1 7.1!!!" which is largely spill-over from the marketing associated with various "gaming headsets" (don't buy those, they're usually awful) - just like how we can thank Beats for getting everyone insisting on needing ANC. :rolleyes:
That doesn't mean it isn't a worthwhile feature if used correctly, but it isn't a magic bullet that will cure cancer and stop hair loss.
Basically what I'm envisioning for your configuration: Razer Surround on the PC will handle the surround simulacra there, and you can get whatever audio interface you want. Plug the Xbox into the receiver and send 5.1 DTS or Dolby (it can do either, it doesn't matter what you pick) into the receiver, and use the receiver's surround simulacra/HRTF feature (e.g. Dolby Headphone, SilentCinema) if you like that effect there.
For movies you're really going to have to play with the settings you have available to you, and make the choice you ultimately like. I would say its reasonable to completely end and remove the whole "getting the full potential" piece of this discussion because
no matter what you do (e.g. use the Dolby/DTS downmix coefficient matrices, use an HRTF/simulacra package, etc) you're getting the entirety of the audio reproduced via stereo on the headphones. Ultimately it just comes down to how much extra "stuff" you want to season the pot with, and thats all preference.
So much marketing hype here. And I really do mean that. Theoretically yes, but theoretically your body is also awash in all that RF too, and all the food you eat contains chemicals (and is made from chemicals, and in fact your'e made from chemicals too), and 100% of people who consume dihydrogen monoxide are going to die eventually.
Reality: analog signal wiring has been used for almost a century, and as a people/species/culture/whatever we've gotten exceptionally good at understanding how it works, and how to make it work better. Things like shielding and impedance bridging, which in the hands of a modern audiophile marketing rep turn into NASA-esque innovations but in reality are fairly simple electronic principles. You have nothing to worry about here, and I'd say you can safely put the marketing hype around "your computer is noisier than an atomic bomb and will destroy your audio and its very bad you need to buy our [thing]!" out of your mind. Don't believe me? Go look up measurements of modern soundcards and onboard audio - they offer similarly good measured performance as most of the rest of the stuff you're considering, and won't cost "a grand or two" to get there.
Now, this does not mean "0 distortion whatsoever" (that is 100% impossible and anyone who says otherwise is incompetent or trying to rip you off), but it does mean "distortion below audible threshold" (and that "Below audible threshold" is really the watchword here - so what if its visible on a scope down there at -160? you can't hear it, you can't perceive it, so it doesn't exist for you, and you're the one making the payment, not the scope).
Anything with an optical or coaxial input will be a DAC. There's a lot of wishy-washy hijinks that goes in the world of "headphone audio" where all manner of devices become "DACs" or "amps" or whatever else, and there's not a lot of clarity (and of course this helps to perpetuate more FUD to move even more product).
I've honestly never had positive things to say about Dolby Headphone. If that's your preference, don't let me stand in your way, but consistently (and we're talking over at least a decade here) its well into the realm of "klaxon in a box canyon" (like most every other Dolby "fake surround" technology (e.g. Virtual Surround, Pro Logic ad nauseum, Virtual Speaker, Mobile, etc).
Completely agree on X-Fi drivers being a wretched mess. FWIW the new SoundCore parts have significantly better drivers, and are stable, but honestly any modern soundcard (especially at the $200+ mark) is kind of a joke these days - they've basically been left behind by the rest of the world, and have become something of an anachronism.
Pics
Headphones will certainly be more portable than any gear, so its probably most reasonable to have something at your PC that they plug into, and something at your TV area that they plug into. Using the receiver at the TV area basically solves that (and who cares if its not the be-all end-all of the universe - you've said it yourself that usage here is probably 10% of the time, AND its just for movies and games, which represents a significantly lower point of diminishing returns (I'll come back to this point don't worry)). So basically you need a "something" at the desk to plug your cans into.
Something else to think about - you may consider getting a wireless headphone just for the receiver area, for movie watching and whatnot (okay all honesty you could just have a wireless headphone for everything and switch inputs on its base station, and thinking about it that sounds really simple, but I'll be honest in that I'm not sure how Sennheiser or AT's best wireless offerings stack up to the rest of the world, I know AT has one that actually does virtual surround (Dolby/DTS) via its base station too).
Personally I would take Razer Surround over Dolby [anything] 8 days a week, but that's my preference. Some people may feel differently. My feelings and thoughts about Windows 10 aren't appropriate for sharing in a public venue (and besides that, the last time I "went there" a Microsoft shill appeared and proceeded to astroturf and gaslight like it was going out of fashion).
Getting the basic Xonar wouldn't be a bad idea to get around driver issues and if you want the Dolby Headphone feature. I think they also have a USB model if you want more portability, but afaik that's still not going to connect to the Xbox or anything of that sort.
There is no "processing the MKV audio" - MKV is a container, not a codec. The playback application unpacks the container and dumps out the h.264 or VC-1 video and whatever audio, which is then decoded for playback there. None of that "processing" is done in the receiver. Some (relatively expensive) Blu-ray playback software can take the TrueHD or HD-MA tracks and decode them, and there's the (now rare) Asus and Auzen cards with HDMI loop-thru that can decode the bitstream out as well, and then you get multi-ch PCM which can be sent out via HDMI or turned into analog and put out via analog. Alternately, I would assume that there shouldn't be as much of an issue finding a player that can bitstream the lossless codec via HDMI for an external decoder. The whole thing is ultimately a total mess because of how nuts the Blu-ray people went with DRM, so expect a lot of "hackish" or "kludgy" fixes to make it all work smoothly (as opposed to just throwing a Blu-ray into your Xbox and having it bitstream the audio and kick the video out via HDMI to the HT system). I certainly understand the convenience factor with digital downloads and streaming and all that, so I'm not saying "get everything on disc" - just know what you're getting into.
I wouldn't fuss too much with "the fidelity of the lossless vs the other" - the performance of DTS and AC-3 is already high enough as to be arguably transparent (this is that "below audible threshold" thing again), so basically if you've got audio coming out, you're "working" and it depends on how much more fussing you want to devote to tweak things beyond that.
Theoretically Razer Surround and Dolby Headphone should be able to take the multi-ch output from movie playback and do their thing with it, and receivers that offer SilentCinema or Dolby Headphone can do that as well. I say "theoretically" because again we're back to trying to make various applications play nicely together, while dancing around the big'ol DRM gorilla.
Absolutely. The only "gotcha" is if you're dealing with a soundcard that has proprietary drivers that do "something" - that won't be applicable to the videocard's interface. But in terms of "sending the audio out" - the videocard has HDMI, and HDMI is more capable than S/PDIF. This is partly why I like the Razer Surround option, because its interface agnostic. Creative has a similar package that puts their SBX suite on whatever hardware (and based on the same software for SoundCore cards, I wouldn't see any big issues with this - I've never encountered the stability problems that X-Fi was plagued with).
Ultimately it comes down to your preference - if you think Dolby Headphone is the cat's meow, then you need some way to get Dolby Headphone. Currently I'm not aware of any stand-alone software package that does Dolby Headphone (because, you know, that would be too efficient and make too much sense), but you can get Razer Surround and Creative SBX as stand-alone software packages that will run on compatible interfaces.
Why?
Not very much.
Yeah you could, but it won't be from Creative (Creative pushes their proprietary SBX package). The question then is "will it be compatible with the HD 800" - a lot of those cheap devices don't assume they're going to be driving high impedance cans.
1) It's all software no matter what branding is on it. The era of actual hardware audio died over a decade ago.
2) Yes exactly it will output to the receiver (or a DAC, or whatever). It will appear to the receiver to be a 2ch signal, and probably sound very weird if played back over the speakers.
With modern AVRs it is impossible to have a discussion about "and not process the signal further" - they're big elaborate computers with a lot going on inside. Basically treat them like a black box and don't worry about the innards too much, or you'll go nuts. It is entirely possible to have a stereo signal go into the box, and come back out for the headphone side, so you could use it as an amplifier for your headphones taking whatever Dolby Headphone/Razer Surround/Creative SBX/whatever input. If you have a multi-channel (digital) output and select the "right" receiver, it can probably do Dolby Headphone itself (so the computer just sends multi-ch out like a DVD player would) - should be the exact same processing, and the only reason I bring this up is if you've already got (say) Dolby Digital Live or DTS Connect on the PC, it may be a one-stop-shop for a new AVR that has the right blend of features.
Where I say "put it in a black box" is because you don't know, for example, if there's any SRC/ASRC, where the signal is going in terms of other DSP effects, etc. It's not the "straight thru" that equipment of the 1970s and 1980s exhibited, but you can certainly have it not trying to "add" anything. If that makes sense.
Like I said, I've never seen a receiver that will not auto-sense when a cable is plugged in, so if you left that cable plugged into the receiver, it will defeat the speakers.
There's no problem with a well-made and long extension cable, yes the wire has impedance (all wire does) but again we're back to "is it actually going to make an audible difference?" and the answer there: almost certainly not. Grado, for example, states that you can happily daisy chain 3 of their extension cables together before anything should become audible - do you need longer than 45 feet?
The volume control thing is certainly a logistical piece to consider, and beyond what you've already proposed, I don't have any other ideas to add there.
I'm not following this question.
Whatever virtual surround application should be able to take a 5.1 input and give you an HRTF headphone output, but debating "quality" will get sticky because you don't (and won't) know exactly what's in the guts of that software and how it does what it does (because that's their secret sauce). Back of the envelope guess? We're back to the "below audible threshold" argument again.
I just wanted to point out - a lot of S/PDIF receivers will have issues with consistently locking 24/192 (especially via optical).
AC-3 and DTS are 16-bit, as are their real-time encoded variants.
Or lossless transport. Most games source their audio from HBR lossy compressed tracks (to save space and improve performance), and IME the law of diminishing returns for gaming audio is very low (and I said this way up above, if anyone is still awake after what I'm guessing is a post of near Biblical length - I haven't previewed it). Basically I wouldn't buy anything really "hi-fi" for gaming audio, because the fidelity just isn't there in the source material, and in a lot of cases you may end up casting light on the blemishes that do exist. This doesn't mean don't enjoy your high end speakers or headphones, just I wouldn't buy them solely for gaming. I wouldn't worry at all about "hi rez" or similar support for gaming either.
Theoretically it does, but it comes back to "can you really hear a difference?" Personally I cannot (and I've taken the "Pepsi challenge" on this to my own satisfaction, and encourage others to do the same), but maybe someone can - I don't know. I do know that both the DTS and Dolby Digital codecs were designed to be as transparent as possible, and they're a lot more efficient (in terms of bandwidth usage) than other lossy formats (e.g. mp3), but there is also a lot of noise shaping and equalization that goes on to achieve that. My feeling on it is that either way its "good enough" but if you can transport the lossless stream why run from it?
+1. :beerchug:
Speaking of HDMI and PCs, you may go looking for one of these on the used market:
https://www.asus.com/Sound-Cards/Xonar_HDAV13_Deluxe/
There's no 1.4/2.0 support, so it won't do 4K video, but you'll have a soundcard that can actually take the lossless codecs and multi-PCM and send it back out, along with a ton of other features. Windows 10 may get in the way of this working, but I'm guessing everybody already assumed that...:p
Jan 17, 2017 at 4:19 PM Post #12 of 18
That was indeed a biblical post obobskivich! That definitely cleared up alot for me. Reason I want the denon x6300 is it has a dedicated amp for all 11 channels which is awesome, since I plan on adding height channels sometime down the line. It has plenty of features I've wanted as well and unfortunately yamaha is behind them right now in features. I can also control the receiver with my phone or ipad which will definitely come in handy. No need for an ir cable for the remote. I'm sure Denon's virtual surround will be fine for me. One guy said he loved it with his 800's.
I went ahead and bought razer surround and will give it a shot for now. I'll wait on the soundcard til later if razer doesn't do it for me.
Like I said in my last post (sucks it has to be reviewed before being posted, and you probably missed it) I will most likely get a Jotunheim since my roomate will be on the tv alot and tie up my receiver when I'm at my desk. But on the bright side too with the dac built in, I can use it on my laptop when I travel.
I will run a basic rca cable from the sound card to the amp initially to use my virtual surround, and worst comes to worse if I get too much noise over the line, which I doubt, then I will get a modi 2 uber which will get me more input options, but I'm sure I won't need to. I get a tremendous amount of line noise with my receiver currently, and especially with my klipsch pro media 5.1's. I'm guessing having my pc next to them and all the electrical wires doesn't help. Theres so much noise I can hear my speakers when they are on at low volume with nothing playing and it's really annoying. This is why I'm kind of paranoid about using rca, but like you say, I should not notice any sound.
Get the Smyth Realiser A16 when it comes out and be done with it.
Duuuude! That thing looks super badass, but it's a ways away and I would rather not spend 2k on one, haha. I'm already going to buy the 800s, plus an x6300 and more than likely the Jotunheim which will put me out almost 4500. I think I'll be good for awhile!
You may not like windows 10 but it is super solid and I was skeptical at first as well, but it's basically windows 7 on steroids and has extremely nice home theater features.
I'm actually traveling right now and won't be home for another two months. I am tempted to buy the cans right now and ATTEMPT to use them on my asus gaming laptop. Yes, using the standard headphone input, lol. Any idea if I will get any audio? It's all I have at the moment. I may buy the jotunheim when it's available and use it as well for now which would be awesome, but I'll wait and see. Unfortunately it's backordered. Thanks again for all the help guys, I've learned a ton in the past couple days since I've been on here.
Jan 17, 2017 at 11:27 PM Post #13 of 18
@Italiano86
Ahhh... I understand. :) I just thought you're willing to shell out $1-2k since you've mentioned it in your OP, I just skimmed through the replies.
Well, It's just an option. :) Pre-orders for roughly 1,700 now. Have you checked about it's capabilities? Videos etc... It's perfect for gaming and movies, which are the things you're primarily concerned with... Like having the best million dollar surround set ups coming from your headphones heh. :D Or at least that's the claim. But judging from the their old A8 version, I wouldn't be surprised, I own one for 2 years. There's a thread of it here, just in case you're bored :D
http://www.head-fi.org/t/807459/smyth-research-realiser-a16/0_20
Jan 18, 2017 at 7:55 PM Post #14 of 18
Yeah, I saw after I posted...:o
Then it did what it was meant to do. :beerchug:
Pure, unadulterated, marketing, nonsense!
That is literally nothing special or magical in any way - if it has outputs, it has amplifiers (and they can't be anything but "dedicated"). But they throw that word "dedicated" in there and turn it into the second coming.
In the words of the great Tony Stark, I would respectfully disagree. Sure, it may have the "latest and greatest" in terms of buzzword compliance (literally throw all that in the trash and burn it down), but nobody has ever (again IME) beaten Yamaha's CinemaDSP. Often imitated, never duplicated, because it uses real acoustic models and not just some DSP "more noise, more speakers!" marketing fluff. If you want to go beyond native 5.1 playback, CinemaDSP or LOGIC7 are the only places I'd bother. If you need 73,000 badges on the front of the device to sleep okay at night, that's another story altogether, and you'll have to deal with that on your own.
Basically everyone has this, it isn't new or revolutionary. There are boomboxes that do this. Yamaha has also had web UI (again, this isn't unique in 2017) for their products.
What does it offer as far as "virtual surround"?
Honestly I think RSP is the best solution there is, and it being interface agnostic is just icing on the cake. Be sure to play around with the calibration and enhancements as they can (and do) make a big difference in whether or not you have a good experience.
I'm not intimiately familiar with Schiit's products but that will probably work fine.
That may be the Pro Media 5.1s - they were never known as a high quality or reliable setup (to be even more blunt: they're junk, specifically the amplifier component is junk; the speakers themselves are fine enough and can be re-used elsewhere though). Doesn't the Jotunheim have digital in? (went and looked it up - it does, via USB) I'd say "worst to worst" just plug into the USB there and be done with it.
While I know better than to comment on this because it may (read: probably will; and I can already predict the retort: "you're just closed minded and need to just open your mind, expand your horizons, and give it a try, and then you'll see its really great!") start a fight (and I don't think it should start a fight, because I'm just citing facts to support a dissenting opinion), it has been consistently documented to spy on you/disregard user privacy, to not actually conform to/effect various settings that should be user selectable (e.g. it will silently revert various settings "for your own good," and has been observed to actively seek and destroy third-party applications that attempt to correct this behavior as well), to force you into pushed updates (both Microsoft and third-party device drivers, and there are multiple instances of this causing widespread bricking of machines, not to mention the covert, forced updates that many users experienced during the "free upgrade period" - and before the "that never happened" brigade starts in, not only did it happen, but Microsoft lost a lawsuit over it), and its bloated in every sense of the word. They want to become an advertising and digital content distribution company and use Windows as their flagship advertising and retail platform - that's fine. But count me way out.
You should get audio, but it may be very low level and/or lacking in low-end depending on what the laptop actually has in the way of an output section. But who knows, maybe they've got a little chip amp in there and it does just fine - TI, ESS, and Maxim are really taking over the world with those little chip amps, and they generally sound pretty good too.
Jan 18, 2017 at 10:03 PM Post #15 of 18
I will definitely look at the yamaha. The dedicated amp for all 11 channels is what it is. Unfortunately for most other receivers you need a two channel amp to actually use all 11 channels, so in reality you can only use 9 without an extra amp. The x6300 does not require the extra amp. i"ve looked at other 2k+ receivers and this is the only one that says you don't need an amp to drive all the channels. I can't imagine running all 11 channels while requiring an extra amp would be very good, if it even worked.
I will definitely do some research on the yamaha 3060, which seems to be the best they have at the moment. True, 11 channels is a nice feature to have, but if the yamaha is good enough then I could justify getting an extra amp for two extra channels. As long as it has the newest dsp's, like dst:neural  or dts:x then it will definitely be competing with the x6300. I am used to my Harman kardon receivers being warm as well, and I hear the yamm's are not so warm. I wonder if yamaha has anything coming out in the near future to beat Denon. Have you used ymaha's virtual surround by chance?
Since windows 10 anniversary update I have been able to turn off every intrusive privacy feature that I know of. I'm sure there could still be more in the software I may have missed, but I still like the OS. I totally understand where you are coming from. As OS's get more and more updated they can be quite intrusive and people aren't aware of this or could care less. Don't get me started on facebook, lol.
I just ordered the 800's from best buy for 1850 and should get them early next week hopefully.
 Hopefully the cans are loud enough on my laptop for now until I can get my hands on the schiit jotunheim.
