Svperstar
- Oct 20, 2004
So after getting my Senn 595s a few days ago, I am trying to get the best quality output, I am using Winamp since I have been using it for years and I don't really like foobar.
So I did a bit of research and found ASIO4ALL and an ASIO plugin for Winamp, I resampled to 48000(Audigy 2 ZS) and started using it.
Then I found a plugin for SSRC, resampled that to 48000, have been trying it also.
Technically, which is better. Depending on the song I listen too I go back and forth to which one I like more, but it could just be psychological.
Then I found the MAD decoder, which supposedly offers higher quality output than the default winamp decoder, so I set that up, seeing which I like.
So I have 4 possible combinations, but rather then do a lot of testing, technically what is the best between all these?
Thanks
Thanks
