sil0nt
- Jul 25, 2002
I have seen some people talk about their portable battery power supplies in a few threads recently, and I would like to get a few more details.
I am going to be building a mains powered +/- 12vdc power supply which connects via DIN plug on the amp. What I want to do is make a battery pack that outputs something like +/- 10-12 vdc to a DIN. As you can see, my goal is to be able to transparently switch from home to portable power supply.
My plan is to use 10 NiMH AAA batteries per rail. Does that seem about right in terms of voltage and mAH? I chose AAA for size, cost, and I have other devices that use AAA but nothing that uses AA. I know I would have two sets of 10 wired in series, but how do I wire this so that I have +/- rails? Should I use 20 AAA's in series and a rail splitter?
Also, I see people discussing voltage regulators on battery packs and various passive components like capacitors. What is the benefit to adding such devices to a battery pack?
Last question.. what about a ground? I need the pinout on the battery power supply DIN to exactly match the mains power supply in order for this to work. Should I just omit a ground on both?
Thanks for answering my questions,
brian
brian
