Nov 21, 2012 at 4:04 AM Thread Starter Post #1 of 6
007noob007
 will they fit to my need? here is what i will use them for-
i will use the "Audio-Technica ATHM50" on my galaxy s1 with a fiio e6.
first of all- more of the music i listen to have alot of instumant, and i realy want them to be speratet, not a "mushy sound"
and, i listen mosly to flac files, but beacuse i listen to wired music i cant find them all in flac....
[size=10pt]music-  I listen to all kinds of music: rock, Irish music, jazz classical, hip hop (just a bit), Japanese music and a lot of just weird stuff [/size]
[size=10pt](if you are intrested https://www.youtube.com/watch?v=Ron17xFNBf0, http://www.youtube.com/watch?v=WmX_GgozpQs are two very different new song my friend showed me)[/size]
[size=10pt] [/size]
[size=10pt]use- i will mostly listen to them on the bus ( I have fiio e6 if it helps) and in the car (maybe a bit to watch movies at home, and listening a bit at home)[/size]
[size=10pt] [/size]
[size=10pt]More-[/size]
[size=10pt]1) If possible a changeable/removable cable  (this is what get broken most of the time, and i wish to be able to change the cable when it is broken)[/size]
[size=10pt]2) Comfortable for long use[/size]
[size=10pt]3) Looking "ok"( not too important, but will be a nice bonus)[/size]
[size=10pt]4) if possible noise canceling (as much as posible)[/size]
[size=10pt]5) 5)[/size][size=13.5pt]Good music quality, good base, and Good noise separation  are the most impotent stuff (noise separation is crucial)[/size]
[size=1.7em]  [/size]
Nov 21, 2012 at 7:09 AM Post #3 of 6
Hi,
I can tell you that if you are listening to a lot of Instrumental type music, and you want them to be separated then you should not buy an ATH M50
How much do you want to spend.
Good Luck,
Andre
Nov 21, 2012 at 2:31 PM Post #5 of 6
Hi,
You should get these Shures. http://www.amazon.com/gp/offer-listing/B002DP8IEK/ref=dp_olp_refurbished?ie=UTF8&condition=refurbished
Or these Audio Technicas, however the are open back.
http://www.amazon.com/Technica-ATH-AD700-Open-air-Audiophile-Headphones/dp/B000CMS0XU/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1353526221&sr=1-1&keywords=AD700
Nov 21, 2012 at 2:35 PM Post #6 of 6
Also consider the KRK KNS 6400 ($90) or the KNS 8400($140). Both are much better all rounders than the M50 and also significantly more comfortable(especially the 8400).
