"Audio Grade" vs "General Purpose" Capacitors for POWER SUPPLY
Feb 27, 2011 at 6:06 PM Thread Starter Post #1 of 14
TheLaw
Hi,
I'm building an LM3886 amp and for the power supply section, I need 2 10,000uF caps @ 63V. Snap in configuration is preferred.
For the main bulk capacitors on an amp's power supply, would it make any noticeable difference if I used cheaper $7 Nippon-Chemi-Con KMH capacitors vs using. $18 Nichicon KG "Audio grade" capacitors. In the signal path, and throughout the rest of the amp, I plan on using "audio grade" capacitors, but for the power supply, how much sonic difference would it make if I used general purpose caps?
Would I be defeating the whole point of using audio grade capacitors throughout the amp if I used standard grade caps on the power supply? Or not?
Thanks.
Feb 27, 2011 at 6:37 PM Post #2 of 14
I would not use "Audio Grade" caps in the power supply.
Power supply cap serve a different purpose.
One of the main specs to look at for power supply caps
is their "ripple current" spec. Caps meant for "power supply
use" are built differently from "general purpose caps" just
as "audio grade caps" are built differently from "general
purpose caps".
Hope that helps...
Feb 27, 2011 at 6:41 PM Post #3 of 14
Yep I understand you perfectly. I didn't even bother to look at ripple current ratings on the KGs. I bet they would be much lower even than your general purpose cap...
But perhaps not.
THanks.
Feb 27, 2011 at 6:49 PM Post #4 of 14
For "ripple current", the higher, the better.
It's a measure of how much current the cap can
supply to suppress power supply noise.
You will often see lower ESR along with higher
ripple current specs.
Feb 27, 2011 at 7:50 PM Post #6 of 14
I meant the KGs ripple would be lower than even standard grade since they are supposed to be for audio and not power supply. Sorry for my crappy wording.
Sorry, but that's usually wrong.  Audio-grade caps are often much worse in ripple than standard grade.  That's the whole point: audio-grade may sound good, but their specs suck.
Feb 27, 2011 at 10:33 PM Post #12 of 14
Wow. Can I not properly write anymore? That's what I meant. The Nichicon KG Audio caps would have lower/worse ripple than other similar non-audio caps.
No, you were right on that one.  I was thinking worse is less ripple protection, but the rating is actually higher on the better cap.  My mistake.
I think cobaltmute is trying to point out that there are exceptions, that's all.  Ultimately, it depends on the power supply and amp design.  If your amp design/power supply has an inherently high psrr, then standard or "power-grade" caps are what you want - because, as you pointed out - the ripple rating is much higher on those caps.  On the other hand, if you're dealing with a run-of-the-mill power supply and amp design (not optimized for psrr), then you may still be better off with audio-grade caps.  This is because the audio quality will filter all the way through the amp into the sound output - non-audio-grade caps, bad sound - even if they're in the power supply.  Most of the stuff around here is inherently high in psrr.  Where you see audio caps making a difference in the power supply is in commercial hi-fi components - CD players, receivers, tuners, etc.  There you may have noticeable improvements in sound quality by bypassing power electrolytics with some audio-grade film caps, for instance, etc., etc.
Feb 28, 2011 at 4:55 AM Post #13 of 14
Please don't spent too much money for audio grade parts for lm3886 amp. It's no use. Just audio caps in signal cap. That amp is maybe "cool", but it's nowhere near as good discrete amp (bipolar/mosfet). Choose wisely.
May 24, 2024 at 10:37 AM Post #14 of 14
Hi,
Thanks.
All a capacitor does is store electrons and then release them. They either work or they do not. So called audiophiles can debate this until the cows come home but no one can convince me that one will sound different than another especially in the power supply. As long as the power supply is well designed and provides the proper voltage without noise it doesn't matter what caps you use as long as they function properly. Better quality caps will last longer and may have better tolerances but it all depends on the design. Designers factor in tolerances.
