doctafonk
- Oct 5, 2005
Does anyone know of a way (on Windows XP) to output my audio via two separate soundcards simultaneously?
TIA
TIA
Originally Posted by doctafonk /img/forum/go_quote.gif Sounds good, NiceCans. Ill check it out. Actually, it would be rare, if ever that I would be listening through both at the same time so the echo wouldn't be a problem for me. |
Originally Posted by c0mfortably_numb /img/forum/go_quote.gif If you use Foobar for your audio player you can go to the preference and select which output to use. Thats how I have my 2 cards working simultaneously, Foobar output to ASIO, and the windows sound preference is set to the other card. |
Originally Posted by doctafonk /img/forum/go_quote.gif no, that's not what I meant by 'simultaneously'. I want the same sound coming from both soundcards (regardless of the app). |
Originally Posted by ericlikeseatin /img/forum/go_quote.gif could you give us the context of this problem? maybe it would help us find a solution. ![]() |
Originally Posted by doctafonk /img/forum/go_quote.gif My USB mixer is my primary "soundcard" when I want to play music through the stereo system, but I also have an X-Fi that I want to use on occasion (eg: just for headphone listening, or if I want to have a quick listen to something without having to switch on the all the audio equipment). It'd be nice not have to manually switch around in the XP sound settings every time I want to change. |
