RoyDaniels
Hello,
I've got this problem for a while now.
When I use over ear headphones I can't hear any noise but when using IEMs it's really annoying.
I use a JDS Labs atom+ stack and wanna use it with my Sennheiser ie 300s.
At first I thought that the stack is too powerful for iems but even when I use a cheap 30€ soundcard
I still hear that noise. I pulled every plug from my pc one by one to see what causes this and the result was that
the connection between my pc and dac / or just the usb soundcard conducts the noise to my iems.
And I've tried several other usb ports. The gain setting on the amp has no impact either.
I even hear the noise when I unplug EVERYTHING besides the connections to my Dac / soundcard
and turn my PSU off I still hear the noise, so it's not related to the electric circuit in my room.
The noise goes silent when I touch any metal that is connected to my pc, I guess everything conductable.
Means, when I touch my 6,3mm to 3.5mm adapter that goes into the amp, the cinch cable that is connected between my
Dac and Amp or even my condensor microphone, which has a metal chassis I guess.
Also what I didn't try until now was letting my brother touch the adapter and when he does, the noise remains, whereas when I do it, it disappears. So I guess I'm grounding myself?
What is also weird is that the noise is always on the right side of the earphone.
I even switched the iem housings to the opposite side (left housing on right the side of the cable and vice versa).
I tried my iems also on my brothers pc and of course my phone and there's no noise whatsoever.
So I guess the noise comes from inside my pc?
Thanks in advance
Thanks in advance
