magicalmouse
Hi, i connected up my card to my dac using the cable that works with other equipment (so the cable is not the issue).
My soundcard works fine with headphones and lineout but when i select spdif there is no signal reaching the dac
I am using various music players - mainly foobar - set to direct sound (asus essence) and in win8.1 the soundcard shows up as functioning perfectly (as it does with headphones and lineout) - i want to use the spdif as my dac is superior to the soundcard dac.
I have tried the various options - spdif bypass, wasapi all variations but nothing works.
Any ideas - i would guess there is a conflict somewhere but I cannot identify it - any software that can do this would be appreciated if nothing else can be suggested.
thanks
d
thanks
d
