smartins
- Mar 21, 2005
I've been meaning to post this a while now but I kept delaying it just to make sure these differences where really noticeable, which I'm now convinced they are indeed.
I've started using Foobar2000 a while back after reading about all the recommendations this player had. For output I chose ASIO with the foo_out_asio.dll plugin available for download from their foobar's website (184,320 bytes) which seemed to offer the best quality.
Recently I've seen a recommendation for MediaMonkey so I gave it a try. I actually liked it a lot and also noticed that it sounded different (better) when using the ASIO plugin. MediaMonkey's uses WinAmp plugins so the ASIO plugin I'm using is the out_asio(dll).dll (SSE2 version) from otachan.com.
My findings when comparing the SQ of the ASIO output of foobar and MediaMonkey (or WinAmp as the plugin is the same) are the following:
MediaMonkey/WinAmp: More fun to listen to, the bass is more present and the mids and highs are "there" but not as harsh as foobar.
Foobar: In comparison to MediaMonkey/WinAmp it sounds more cold, with less bass and with harsher highs.
I've done several comparisons over the last few weeks and this is the conclusion I get every time I switch back to foobar.
Anyone else noticed this? I don't have any equalizer on and just to make sure I've installed the basic WinAmp with only the ASIO plugin and the SQ is the same as the MediaMonkey one.
