mAurelius
- May 14, 2010
Hello,
I'm making my first foray into this world of Headphone Audio with my first pair of decent Cans...Senn HD 595's. Unfortunately, my main audio source will be a Dell Laptop. I know they are notorious for abysmal soundcards (integrated IDT soundcard).
Anyways, I don't have much to spend at the moment for a DAC, after some research I've settled on the TBAAM as an acceptable solution, seems to get generally solid reviews for the money.
Is there any discernable difference between the Micro and the newer Micro II? It appears Turtle Beach discontinued the old one and has the new Micro II. Both are available on Newegg, I haven't seen a comparison on this site so I thought I'd throw out the question.
Micro:
http://www.newegg.com/Product/Product.aspx?Item=N82E16829118107&cm_re=turtle_beach_audio_advantage_micro-_-29-118-107-_-Product
Micro II:
http://www.newegg.com/Product/Product.aspx?Item=N82E16829118007&cm_re=turtle_beach_audio_advantage_micro-_-29-118-007-_-Product
Any thoughts / advice are much appreciated!
-Aurelius
Micro:
Micro II:
-Aurelius
