Schizeophonic
- Sep 19, 2003
Hi all,
Long time no post, but hoping the community can help with the following issue that I am experiencing in Android 15. Specifically that google has deployed automatic volume reduction when using USB connected devices and there is no way to disable this 'feature'. You can DISABLE it for Bluetooth connect devices, but I am using a USB C -> 3.5mm dongle to feed my car with a 3.5 mm audio input. The car is older and only has a 3.5 mm audio input or a cd player.
The problem is that I like having the volume at 100% on the phone when sending it to the usb dac/dongle since it sounds the best when used like this (clarity). I control the volume via the car's volume control. I don't listen at loud volumes. However, after periodic intervals, android lowers the volume automatically to 'prevent hearing loss' since it believes I am using headphones. I am not, so this basically totally kills the volume level while I am driving, and I have to try to turn the volume back up while driving. It is also a manual and fooling around with this while driving is both silly and dangerous. I usually just drive around in relative silence after this. It is really frustrating. I have contacted Google support many times with no resolution, and in googles own support documentation the OEM provider of the phone can control whether you can disable this or not. For Pixel devices, it appears you cannot and I have tried everything.
Does anyone know of a workaround for this issue? I have looked into the app 'USB Audio Player Pro', since this app appears to bypass the Android OS audio stack to avoid this tomfoolery. Any simpler solutions? Hardware that I could buy? I prefer the simplest solution so that I can just go back to listening to music/audiobooks without interference. I am literally thinking about just using my Ipad in my car since I haven't found any apple devices that suffer from this issue.
Any help that anyone could provide would be greatly appreciated. There are many threads on reddit about this issue and I think that this may increasingly become a problem with our devices and would prefer to know how to navigate going forward.
Documentation below:
https://support.google.com/pixelpho...ications,turn-notification-cooldown-on-or-off
https://source.android.com/docs/core/audio/sound-dose
Examples on Reddit:
https://www.reddit.com/r/GooglePixel/s/ib8P7A0glq
https://www.reddit.com/r/GooglePixe...mly_lowering_on_its_own_on_pixel_6/?rdt=35354
https://www.reddit.com/r/GooglePixel/comments/1at8wsq/pixel_7_pro_volume_changing_on_its_own/
https://www.reddit.com/r/pixel_phones/comments/u54vof/volume_keeps_lowering_randomly_on_pixel_6/
https://support.google.com/pixelphone/thread/162706324/volume-keeps-turning-itself-down?hl=en
Examples on Reddit:
