mrjames
Hi there,
My AKG broke down recently. It trully was a sad day (not that I'm a materialistic, they were just my treasure). So I need a replacement. I thought of getting a new pair of the same model, but then I remember I would also need an amp, which I don't have (they are supposed to be used with an amp, right? I do remember using one at the begining, but it stopped working shortly after the purchase and I didn't bother getting a new one. I guess I got used to them without any amp). The problem is: I'm in a budget right now, so I'm looking for a headphone with similar sound/comfort that doesn't requiered an amp (I know, too good to be true). Alternatively, I would consider gettin a new K612 pro + a BBB amp (Good Pretty and Cheap in spanish) if the latter isn't too expensive (which is a feacible option, given that the K612 pro are cheaper now).
Any advice would be appreciated. I don't believe my ears will last much longet with eardbuds 24/7. And just to be clear, my budget is 100-150 euros (including the amp, if there's one).
