Advice od headphone output...
Mar 22, 2003 at 10:06 PM Thread Starter Post #1 of 2
culp4684
I own a Sony MZ-E10 and use a pair of Seinheiser 400's for portable use. At home I use my Grado 125's.
I'm looking for a pair of phones as an upgrade to the Seinheiser (not buds) for portable use. In comparing certain models, what standard is used to determine how loud the music sounds? Is it the sensitivity or the impeadance or both?
I ask this because I notice that the Koss PortaPros are close when it comes to sensitivity, but miles apart on the impeadance. In fact, my Grado's are right in between the two in that department. I have no problem with the volume level with the Grado's on the MZ-E10, but the volume on them is limited when using an MZ-N1.
Mar 22, 2003 at 10:22 PM Post #2 of 2
Dare I mention the hype-words of the moment... Eggo and D66?
With both I suppose you should be looking for high efficiency and reasonably low impedance.
