blackmouse78
- Feb 8, 2016
Hi All,
I'm back on the forum after a long time, spent enjoying the setup I've put together thanks to your advice
So... I'm back in selfish mode trying to get more advice from good willed members of the community.
I'm a lousy guitar player, but I'm now spending more and more time with headphones connected to my stompbox and electric guitar.
I've got a pair of HiFiMan HE400i which I use for music listening, but those are way too quiet when connected to the stompbox, and I can't/don't want to connect the amp/DAC that I have (Grace M9xx) to the box, and I've ended up using the Koss SportaPro that I normally wear when running....
Theys sound ok and loud enough, but the wire is short, not interchangeable, and they tend to get uncomfortable after a while...
This is why I'm looking into a pair of half-decent "studio" headphones, with a longer wire (possibly detachable, but as long as I get at least 2m non coiled wire I'm ok), closed back, and easy to drive.
Build quality and comfort are important, I don't want to have to pamper them, and might want to use them as portable/travel gear, but this is just a second field of use....
I'm not particularly bothered by "flat" frequency response, which is often a requirement for "studio" headphones. I'm playing my guitar and recording occasionally, but surely won't be mixing stuff... As long as the frequency response is not totally crazy basshead-style I'm fine!
My budget would be below £100
I had tried a pair of Audio Technica ath m30x to give you an idea of the kind of gear I'm looking at. Got them from Amazon Warehouse, were supposed to be "like new", but the plastic on one of the swivels had a crack, right out of the box, so they wouldn't even sit symmetrically on my head unless held in place with my hands. That's a shame because they sounded fit for purpose and ticked all the boxes... I've read online that also the m40x have similar issues with the plastic not being tough/durable at all, so I'm steering clear from AT.
Too bad beacause they seemed just right...
I've looked at Shure SRH440, but they come with a coiled wire and I don't want to spend extra ~£20 for an aftermarket wire, but so far they seem like my best option.
Sony Mdr-v6 are another candidate, but again they come with non-detachable stupid coiled wire...
Does Sennheiser do anything in that price bracket with decent sound quality?
I'm afraid not.. I like Sennheiser build quality and design but I'm afraid that sound quality would be disappointing in that price bracket....
