I’m happy with my JHA CIEM but I would use it a lot more on the go if I had a true wireless adapter instead of a Bluetooth dongle. But it uses a 7-pin connector.
Have you ever come across an adapter to convert 7-pin from/to MMCX or 2-pin?
I had some for Etymotic in the past. And I’ve found one on AliExpress for the more common JHA 4-pin connector.
From JHA I can only get a repair if I ever need it or a 7-pin cable.
Thanks!
Thanks!
