Originally Posted by dweaver /img/forum/go_quote.gif
You know 1Time, I hear what your saying, a swivel would help out.
No. What I mean is the design is essentially defective. A vertical swivel would not simply help; it would correct the defect.
But one thing I find interesting is when I I open the phones like I'm going to wear them the phones look like ther are in the right angle. But when I look in the mirror after putting them on they are more more compressed at my jaw.
In stock form the lower part of the ear cups presses harder at the jaw than the top part presses on the head. And, for many the fit of the AD700 is too loose (it was for me). A proper fit is when the ear cups press evenly around / on the ears, and the headphones are not too loose or too tight.
After modding the AD700 with rubber bands or bending, the fit no doubt would be tighter and the sound should be improved. However, modding in this way must increase the inward angle of the ear cups. If the ear cups are brought closer together by either of these mods and
without bending the angle of the ear cups outward, the inward angle of the ear cups must increase accordingly. The result: the lower part of the ear cups now must press proportionately harder than the top part of the ear cups. The inward angle of the ear cups is increased, but the angle between one's head and jaw remains constant. That means even though these mods make the fit tighter, they also make the fit more improper. The headphones sound better after the mod because the fit was so screwed up in the first place; the drivers were too far from the ears. Modding just puts the headphones close enough to the ears for it to sound better. However, these mods make the angle of the drivers worse than stock. There is nothing "proper" about the fit of AD700 for practically anyone, stock or modified. You'd have to have a very wide head to very narrow jaw width ratio for it to fit properly. Picture an alien's head shaped like an inverted triangle and you get the idea.
Having said that I find they are still very comfortable.
I don't read many complaints about the comfort of the AD700. In stock form, I found it uncomfortable because the lower part of the ear pads clamped too much on my jaw. I did not bother stretching the ear cups wider apart to make it more comfortable because doing so would have made the top of the ear cups fit even looser.
It only makes sense that a proper fit would result in improved sound and comfort. A proper fit for practically everyone would require the ear cups to be bent outward, and I don't recall ever seeing a picture posted showing this done. And when I owned the AD700, I did not see an option for how this could be done.
But I do wish these manufacturers would spend a bit more time to make their phones more ergonomic in design.
No need to blame other manufacturers. FWIR, the AD700 and the similarly designed Audio-Technicas are an aberration in the world of headphones. They stand alone and apart in regard to the degree to which they do not fit properly for practically everyone, stock or modified. Again, Audio-Technica should be lambasted for this failure.
Now, does that mean I'm saying the AD700 cannot be enjoyed or comfortably worn by some. No. If there were a way to mod the AD700 for a proper fit, I would re-buy, amp it, and post pics with a proper review. I tried pushing it to my ears to see if modding it may be worth a try. But I soon determined the AD700 did not have enough bass for me and then sold it. And so until then, I agree with most in that it does not fit properly and it is bass light.
