(4.4mm) Internal or External Sound card for PC
Jan 7, 2020 at 1:08 PM Thread Starter Post #1 of 3
Rpyy
Bangkok,Thailand
I really wanna upgrade my computer audio quality and my IEMs are 4.4mm balance
any recommend for Sound card with
4.4mm Balanced Connection?
Is it possible to have 4.4mm connection on PC sound card, if yes? please suggest me or I should go for 4.4mm to 3.5 adapter.
Jan 8, 2020 at 8:26 PM Post #2 of 3
I would assume(?), the 4.4mm (TRRS) to 3.5mm (TRS) would work.
What is the make and model of your IEMs?
Jan 9, 2020 at 7:57 AM Post #3 of 3
@Rpyy,
Few DACs, audio interfaces, let alone soundcards have 4.4 mm output yet so I suggest simply getting a 4.4 mm female to 3.5 mm adapter, this will be the easiest, most affordable option as well.
penon-official.com will have what you need.
Hope you have a great day !
