darkarn
- Mar 16, 2012
Hi! I am interested in doing line-in recordings and I need something portable. After realising that my laptop (using Realtek ALC892) could do only 16bit/192khz recordings, I decided to research more and had the following options.
Option 1: Portable Recorder (Zoom H1)
I read that they can do up to 24bit/96khz and very portable. Problem is, a SD card can never hold as much as a laptop. I was a little uncomfortable with it converting all recordings to WAV immediately (unlike the laptop which allows me to record everything in Audacity, which I could then edit and then turn them into FLACs.)
Option 2: Laptop with Creative Sound Blaster X-Fi HD
I also noticed that it could do 24bit/96khz. I am considering it as it allows me to record everything in Audacity, which I could then edit and then turn them into FLACs (unlike option 1). But I am hearing reports that Creative is getting bad to worse...?
Option 3: Laptop with ALC892, using Microsoft's drivers AND USB DAC+Amp Combo
Based on this thread elsewhere that I have just read, I realised that my laptop could actually do 24bit/192khz recordings, but required me to lose the usage of some of my onboard speakers after changing to Microsoft's drivers. Also, since I can only afford one of these, I am going to get the DAC in this option and use it to help with the recording.
Hence, what I really need help in is knowing which option provides the best quality. Or rather, am I making sense in deciding these (still quite new to the audio scene here)
Thanks!
Thanks!
